Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Washing & Waxing
Washing & Waxing Washing and Waxing your Dodge Ram! Talk about it here!
Old 07-03-2010, 02:26 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
Default water spot removal
ended up with some water spot imprints on my hood scoop. used rubbing and polishing compounds and waxed the hell out of it - still there at certain angles...
i don't have a buffer, what else could i use to take these out?
Old 07-03-2010, 08:43 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Have you tried a clay bar and then a good wax like Zymol.
Old 07-03-2010, 12:29 PM
Leadfootluke Leadfootluke is offline
Vehicle: 1998 Dodge Dakota
Rep:276
Leadfootluke is a jewel in the roughLeadfootluke is a jewel in the roughLeadfootluke is a jewel in the rough
I don't think spending several hundred on a wax is going to help him out
Can you post pictures?
Old 07-04-2010, 01:59 AM
jayhkr's Avatar
jayhkr jayhkr is offline
Vehicle: 2006 Dodge Ram SLT 4x4
Color: Atlantic Pearl Blue Metallic
Rep:75
jayhkr will become famous soon enough
Send a message via ICQ to jayhkr
Need to strip the wax off using the claybar and 50/50 mix of isopropyal alcohol and water. Depending on how deep the water etch is, you will want to get a heavy cut compound, I recomend Megs 105/205 and a foam pad. If you were near the KC area I could take care of it for you in about an hour if was just on your scoop.
Old 07-04-2010, 06:11 AM
UltraFlame's Avatar
Rep:840
Zymol is not that expensive. The clay bar kit at almost any auto parts store is only about $20 and the Zymol is about the same.
Old 07-04-2010, 08:26 AM
Hopefully it's something you can take care of . I've seen spots caused by acid rain that theres nothing you can do with .
Old 07-04-2010, 11:07 AM
Rep:276
Clay bar kit, yes, but where are you getting the Zymol for $20?
Old 07-04-2010, 01:31 PM
Delasangre's Avatar
Delasangre Delasangre is offline
Vehicle: 2001 Dodge Ram 1500 2x4 5.2
Color: blue
Rep:31
Delasangre is on a distinguished road
I hear yah man, water spots suck. Mine has had them since I bought it used from a local lot. I've spent hours trying to remove them with every method mentioned here and still cant get them all out.
Old 07-04-2010, 01:57 PM
Trim Level: sxt
Rep:197
the truck is dirty now, ill wash it and put some pictures. two weeks ago, spent an hour and a half on the scoop - thought i got them all but next day
you can only see them at certain angles, but the fact they're there bothers me.
Old 08-29-2010, 01:10 PM
dafoot dafoot is offline
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
Go to your boat or marine store. There are products made to clean boats, that will remove hard water spots. I have been able to remove hard water spots from black Mercury moters using these products. Good luck and let us know if that worked for you.
DAFOOT
