Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Place your Ad Here!
Old 07-12-2010, 11:55 PM
Dusky Dusky is offline
Vehicle: 2010 2500 HD Crew
Color: Greystone
Dusky is on a distinguished road
Thanks for the additional info. I had two more "damaged key" incidents the next day after my last post but was able to get it started after jostling the key around some. I haven't been off the road long enough to get it to the dealer so I'm very interested in how the fix works out.
I couldn't afford to get stranded so I have left the key in the ignition for a week or so now with no problem (unlocking with the "real" key).
It sounds like it may (hopefully) be an easy fix but has been a royal pain for the last week or so.
Old 07-15-2010, 01:12 PM
Color: Greystone
Default Towed In
Same problem again today...."Damaged Key" message and constant chime with no key in ignition. All other interior electronics unresponsive.
Tow truck just left taking it to the dealership. I put the key in a sealed envelope with instructions for the service department to not to put the key in the ignition until they saw the problem with the damaged key message.
I'll post the outcome.
Old 07-16-2010, 06:58 PM
Color: Greystone
Default Conclusion
Checked for codes & found WIN module causing no start condition. Replaced module and reprogrammed keys (FP Number 68064789-AE, Module WIR 8035031).
Tallahassee Dodge did a nice job of squeezing me into a busy shop.
Old 08-07-2010, 07:40 AM
airbee airbee is offline
Vehicle: 2009 Ram 1500 Sport Quad 4x4
Trim Level: slt/sport
airbee is on a distinguished road
Default Follow-up - Key in Ignition
Replacing the Wireless Control Module - WCM has worked.
Old 08-26-2010, 05:03 PM
MrB MrB is offline
MrB is on a distinguished road
Default Damaged Key
I have a 2010 Ram 1500 (got it in July 2010) and have already had a problem with the "Damaged Key" coming up on my console. First time was after I removed the key. I was able to restart the truck with no problem. Second time was when I went to insert the key. Damaged Key message display and truck would not start. Jiggled the key around a couple of times and it finally started. Final time was with the truck running. Turned the key to off and the truck kept running. Got the spare key and had no effect. Drove to the dealership with the key in the off position. Truck would not shut off even at the dealership. The ran some diagnostics and said that they had to order a new WCM module.
Hopefully, this will fix the problem.
Old 08-26-2010, 05:11 PM
Resident Technician
Rep:1915
That's not an uncommon problem. There is a new vendor supplying the WIN modules now.
Old 12-22-2010, 11:22 PM
Richardito
Default Me too!
I turned off the ignition key in my 09 RAM 1500 and pulled it out at a slight angle and felt some pressure. After that I started getting the "Key in the Ignition" message. The funny part is that the truck will no longer lock the doors using that remote, but I can lock it using the other remote. So now I'm carrying both remotes when I use the truck. Should something meant for use in a working truck be so fragile? I need to call the dealer ASAP.
