Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
tonneaucovered.com
Old 07-04-2010, 01:01 PM
DodgeAtron DodgeAtron is offline
Vehicle: 2002 Dodge Ram, 1500, sport.
Color: silver and black
DodgeAtron is on a distinguished road
Default Front end creaking and moaning?
Any one have an idea why My front end in my 02 1500 is creaking and moaning when I go over bumps and or turn left?
Old 07-04-2010, 01:06 PM
When was the last time it had a good ole grease job ?
Old 07-04-2010, 01:07 PM
Resident Technician
Rep:1911
Because it's an '02 that has most of, if not all of its original components. Break out the spray lube and start hitting the bushings for starters.
Old 07-04-2010, 01:23 PM
I'm rotating my tires today, so I'll have good access to lube everything up. I'm hoping thats all it is, I do drive her on construction sites, very dusty and dirty, my brakes even when new usually squeak on the way home from work, so lets hope that will do the trick. Thanks
Old 07-04-2010, 02:57 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:446
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I'd pull the sway bar bushings off and clean then grease them, You might drill/tap and install a zerk in each one, just drill thru the rubber bushing so grease can penetrate. Of course if they are worn badly, get new ones.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 240,000 miles To Hell and back. 14.2/96 mph NEDW
