Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 07-05-2010, 11:29 AM
peppy peppy is offline
Vehicle: 2010 Dadge Ram 1500 Quad cab
Rep:23
peppy is on a distinguished road
Default The plasitc bed sides
Does anyone know how/if the plastic sides on the bed of the truck can come off with out breaking them?
Old 07-05-2010, 11:58 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
They have plastic clips molded to the back side of them. I THINK you can pinch them closed and pop them off. Look under the rail n a bout (4) places for the plastic nubs protruding through.
My covers keep warping and the corners pull up. I'm on my second set (under warranty) but I'd rather be done with them and have the spray-on bed liner come over the sides. The problem is the bed rail has an indentation to fit the black cover the looks terrible by itself and the (4) square holes look unfinished without the cover as well.
Old 07-05-2010, 04:45 PM
Rep:2616
I have thought that they should make metal caps that fit where the plastic caps are
on the older generation Rams, i have seen diamond plate caps that cover the holes & indentations, the metal caps could be shot with Line_X or powder coated to any color choice & then you could easily mount just about anything on top of the bed rails
I just did a web search, it reads that they do have metal bed caps for '09 Ram
this is what i came up with
Dee Zee Brite-Tread Side Bed Caps & there are other companies that make them also
Old 07-11-2010, 10:40 AM
Barnyard's Avatar
Rep:209
Good thought! I'd go for that even though I'd have to re-drill all the mounting holes for my after-market tie-downs!
