Old 07-05-2010, 03:38 PM
CL743115@wcupa.edu
Default 35" Tires- Needs some help
Alright, so I have a 1997 Dodge Ram 1500, extended cab, short bed. It has a 5.2 L magnum V8 engine.
I just recently went to the junkyard and bought 4 35" tires. We tried putting them on the Truck but at it's current height, the tires aren't able to turn all the way. We were thinking about getting a 2" lift to fix this problem. Will that be enough of a lift, or will I need to go higher?
Old 07-05-2010, 03:42 PM
iRESQu iRESQu is offline
Rep:2217
Welcome aboard as I see this is your first post. I THINK 2" will work. Not sure I would do only a 2". Are you 4x4? I believe a 3" is more commonly accepted for 35's.
Old 07-05-2010, 06:04 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Welcome to the site. Dont forget to introduce yourself in the newbie checkin. I think a 2-3" lift would work pretty good.
1997, 5.2 liter, dodge ram 1500, lift, tires
