Old 07-05-2010, 07:21 PM
RammD RammD is offline
Vehicle: 2010 RAM SLT REG. CABX2
Color: CRYSTAL BLACK PEARL
Rep:61
RammD will become famous soon enough
Default What's our Stock T-STAT? Any benefit to swapping it?
I'm just asking this b/c I know with my last car (Charger) I ended up swapping the stock T-STAT which got really hot in the summer and caused the Hemi to get "sluggish." I swapped it with a 180 Jet T-STAT and the problem was solved. That was a 2007 Dodge Charger, 5.7L HEMI.
What T-Stat comes with our 5.7L Ram's? Any Chance Dodge finally got it right and shipped them with a 170 or 180 T-Stat or would it be advisable to once again change the T-Stat in the Ram? Thanks.
Old 07-05-2010, 07:25 PM
Resident Technician
Rep:1909
Same stat comes in all the Hemi's. It's not a matter of "getting it right". Running them a bit hotter helps reduce emissions.
Old 07-05-2010, 08:05 PM
Rep:61
I see, thanks for the reply. So would it be safe to say that a lot of Ram owner's, just like Charger owners...swap their stock T-STAT's with a 170 or 180? I mean, is this as common a mod on the Ram's with the HEmi's as it was with the Chargers?
Old 07-06-2010, 02:05 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
..I run a 180 tstat...and yes it is very common with the guys who do mods..
Old 07-06-2010, 02:12 AM
chefred112's Avatar
Rep:656
..a big worry with the guys who mod is runnin lean, pre-detonation an knocking...using a lower temp tstat will add fuel... one less worry when I'm out driving around a little bit on the spirited side..
Old 07-13-2010, 04:29 PM
SpeedlogiX-Mikey SpeedlogiX-Mikey is offline
Rep:40
SpeedlogiX-Mikey is on a distinguished road
We sell them! It would be a Jet 180° Thermostat. Let me know if I you would like to purchase one, they are $30.88 before shipping.
Old 07-13-2010, 06:11 PM
I think you'd see the same improvement in a cooler running engine with a lower value TStat.
A couple things to consider:
1. If you have electric fans, you won't see the full benefit until you add a programmer that will allow to you change the fan settings.
2. If it runs cooler, you may end up with a bit more oil trying to return to the combustion cycle through the PCV system. That can be alleviated (and reduce TB sludge as well) by installing a catch can. I can't put a catch can on my 2007 but for those of you who can tap into the PCV return lines to the intake manifold, get yourself one!
Old 07-14-2010, 10:40 PM
ScatPak07's Avatar
Rep:970
I have installed a 180 Tsat on my 07 Ram and I notice it runs cooler now. It is a little better of a ride but nothing crazy. I think the stock Tsats are like 200 or 220 something like that, but dont quote me on that haha.
Old 07-15-2010, 10:22 AM
chefred112's Avatar
Rep:656
..I beleive stock is 203 degrees..
Old 07-18-2010, 11:48 PM
RamLover's Avatar
RamLover RamLover is offline
Vehicle: 09 1500(Dodge Ram.. obviously)
Color: Mineral Gray
Rep:58
RamLover will become famous soon enough
Hey Red how does the Tstat factor into how much fuel the engine gets??
TOO MUCH IS JUST ENOUGH!!
