Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 07-05-2010, 10:55 PM
Bigman Bigman is offline
Bigman is on a distinguished road
Default True Dual Exhaust System
I currently have the sport 5.7L Hemi with dual out exhaust. I am looking to put on a true dual exhaust system. Does anyone know if this is okay or will it screw up the trucks computer system or something?
Thanks!
Old 07-05-2010, 11:21 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I'd think it can be done if a competent tech did the work. You're looking at two CATs, and two mufflers plus doubling the sensors (this is where the good tech comes in) plus telling the computer what's what.
If I were doing it, I'd also put a set of headers on. No sense in going to all that effort and expense and only doing half the job.
Brian:
Old 07-06-2010, 04:24 AM
My09 My09 is offline
My09 is on a distinguished road
Thanks!
I know it has been done already. The gentleman has an 10' R/T. He took is truck into a local shop and showed them exactly how he wished to have it set up while it was on the lift. I forget the specific's as far as keeping/removing the cats, muffler and resonator's etc..I do know he is very pleased with the outcome and has not had any issues with drone or throwing codes. Brianwl is correct about having a competent tech do the install as the whole process is something that require's a seasoned professional's direction and fabrication.
2009 RCSB Hemi Ram SLT 2WD 3.92 LSD.
Mods: Sport bumpers Superchips K&N CAI Magnaflow Catback.
Old 07-06-2010, 05:55 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Is there a HP gain to be had with true dual?
Old 07-06-2010, 07:25 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
I would say there must be a gain of sorts. Better air flow can't help but increase performance. I'm just not sure what the numbers on the actual gain will be.
Exco
Bill
Old 07-06-2010, 09:03 AM
SilverUSMC's Avatar
SilverUSMC SilverUSMC is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Trim Level: Laramie / Quad Cab
Rep:20
SilverUSMC is on a distinguished road
I have true dual Magnaflow on my 2008 but didnt notice a big difference until I put in my CAI.
Old 07-06-2010, 09:28 AM
Resident Technician
Rep:1915
There's no need to double up on sensors since it already has 1/1, 1/2 ,2/1 and 2/2 sensors already in place.
Old 07-06-2010, 09:37 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I imagine you'd still want to add an X-pipe even if you run "true" duals, so is there really a gain? Or is it more of a bragging right? What if you just upgraded the stock Y-pipe? Just curious...
Old 07-06-2010, 01:06 PM
black magic's Avatar
black magic black magic is offline
Vehicle: 2008 Ram 1500 QC
black magic is on a distinguished road
I'd hold off until you have heard that somebody has already done a setup like what you are looking at. The reason I say that is because you may actually loose some low-end torque because of the loss of back-preasure. I did this to a GMC a few years back and I felt the loss of low-end torque. Now once I got rolling, I felt the gain (40mph punch, merging, etc.). If you do go true dual, I'd upgrade the intake as well. If your going to flow better going out, you'll need to have better "flow" going in. Also, go with an x-pipe. I'm sure if you search on u-tube you'll find examples of all sorts of exhaust systems and tru-dual setups.
Jake
Old 07-06-2010, 01:27 PM
Thanks a lot guys....and yes i already have an intake!
