Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-06-2010, 12:55 AM
DBITEME2 DBITEME2 is offline
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
DBITEME2 is on a distinguished road
Default Need help with Tranny and A/C
Hi all, I am searching for a simple answer here! I have 99 Ram 2500 4x4 (auto) w/5.9 cummins. It recently started shifting up and down while driving up the road? I replaced the Transmission Output Shaft Speed Sensor (trouble code P0715 & RT Code 10149) and it worked for about 2 days? Dang sensor may be bad ..ok.. but when I hit the brakes hard the A/C blows hot? Can it be a vacuum line or pump? And is the sensor the problem here?? Help Please!!!
Old 07-25-2010, 09:29 AM
mlrtym's Avatar
mlrtym mlrtym is offline
Vehicle: 1994/98 Ram 2500
Trim Level: SLT Laramie
Color: Flat Black
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
mlrtym is on a distinguished road
Default tranny shifting lockup
are you still having an issue with the shifting? we have different trucks, and your tranny is all electronic, but if it is shifting in and out of lockup, then i have an idea for you. mine was doing that, and after spending $3000 on a rebuild, it still did. i would get the trans temp light on and off, and when it came on, it would shift out of lockup - a royal pita on the highway. turns out it was the in-line temp sensor. i removed it and put in a sending unit for a gauge. to clear the idiot light from the dash, i used a 8K resistor jumpered across the stock harness. this shows the computer that the tranny is up to temp, to allow it to use lockup. during the winter, i turn off the OD to ensure that it will not use lockup until it has actually warmed up.
as for the AC, not a clue what would cause it to blow hot air when hitting the brakes. if it were vacuum, i think the only climate control using vacuum are the dampers, so it would not change the temp, just where the air is going.
It is better to let one think you a fool, than to open your mouth and remove all doubt.
Old 12-01-2012, 06:25 PM
jwmiller61 jwmiller61 is offline
Vehicle: 1995 dodge ram 2500 diesel
Trim Level: xlt
jwmiller61 is on a distinguished road
I was and still am having the same issue. What I mean by that is that my transmission was jumping in and out of lock-up. I did all you could imagine including a transmission rebuild. Still having problems. Finally, after all that, I replaced my transmission temperature sensor. WOW!!! That was the answer. But, now at times, my transmission will not go into overdrive at all and the a/c will not work at the same time. I am clueless about this issue. Either both work or both doesn't work. What's the problem? Is there something that controls both?
