Old 07-06-2010, 02:34 AM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
Default Steering Stabilizer issue...
I recently installed a Pro Comp steering stabilizer on my 01 Dodge Ram 4x4 5.9L truck...im a little new the vehicle...i noticed that the "solid frame" piece i was mounting the stabilizer to was able to move/rock almost front to back (perpendicular to the stabilizer) and i was wondering is this normal? I looked liked it had bushings for some movement but i was just curious if maybe i need to replace some bushings or tighten some nuts and bolts...thanks
Old 07-06-2010, 02:37 AM
You should mount it to something stable .
Old 07-06-2010, 02:42 AM
alfonso318's Avatar
Rep:42
it was stable for the most part but i noticed that it had the ability to tip back and forth a little...and i wasnt sure if it was normal or if the "solid frame piece" needed to have zero movement???
Old 07-06-2010, 02:45 AM
I'll look at mine in the a.m.
Old 07-06-2010, 02:52 AM
alfonso318's Avatar
Rep:42
thanks i appreciate it...it was a very minimal like maybe 1 inch or so...like it was a healthy movement to accommodate for rough terrain or bumps to give or something
Old 07-22-2010, 11:21 PM
mjonesjr's Avatar
mjonesjr mjonesjr is offline
Rep:12
mjonesjr is on a distinguished road
The frame mount for the steering stabilizer should NOT be moving.
1996 Dodge Ram 1500 Club Cab, 5.9L V8, 4x4
