Old 07-09-2010, 09:24 PM
allenw88's Avatar
allenw88 allenw88 is offline
Vehicle: 2005 Ram 1500 5.7 Hemi
Rep:22
allenw88 is on a distinguished road
Default Rear View Mirror
Was wondering how to get the rear view mirror off. Was wanting to tint the front window (eyebrow) but was needing to get that off to get it looking a little better.
Old 07-09-2010, 09:59 PM
ScatPak07's Avatar
Rep:970
When I got mine tinted the guy just slid it off but kept the piece that sticks to the window on. If you cut around that piece perfectly like my guy did it looks good! I forgot how he took the rear view mirror off but it came off pretty easily.
If you take that piece off the windsheild you may have trouble getting it back on. It is 3m double sided tape holding it on there. Trust me it does not look bad if you cut around it precisely.
Old 07-09-2010, 10:18 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
You probably don't want to do this! Like Scat says, slip the mirror off the mount and cut the film around the mount. If you take it off, tint the window, then reapply it to the tint.....it WILL come off and damage the tint and you will be oh so upset when you have to re-tint the window, only to repeat the process....about every 4 months.
brad
Interested in one of my mods?
Old 07-09-2010, 10:25 PM
You should be able to remove the mirror . I would not attempt to remove the metal plate . You would probably damage the windshield . If at all possible cut the tint out around the metal plate . That metal tab will fall off with the mirror in about 5 yrears when you least expect it . Then you can get the mirror installation kit and reinstall it .
Old 07-09-2010, 11:07 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
On the window mounted mirrors there is usually an allen type set screw holding the mirror to the mount which as others have said is glued to the windshield. Loosen (do not remove) the screw and the mirror just slides off.
The screw should be at or toward the bottom and the mirror should slide up.
Brian:
Old 07-10-2010, 07:53 AM
allenw88's Avatar
Rep:22
Yeah sorry didnt specify...LOL.. i was not looking to take metal tab off. Just the mirror portion. I did it to an old s10 of mine (leaving tab metal tab and cutting around tab) and it looked great...I will check on the Allan Key deal (thx Brain). Will post pics when I am done with
Old 07-10-2010, 06:19 PM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
let us know how it comes off i needa tighten mine! my sub makes mine fall off
Old 07-11-2010, 01:10 AM
gtfloyd's Avatar
gtfloyd gtfloyd is offline
Vehicle: 2008 Ram 2500 4X4
Color: WHITE
Rep:21
gtfloyd is on a distinguished road
ORRRRR...you accidentally hit a series of ruts in the middle of nowhere while mudding and knock off your mirror and send your toolbox into disarray. It took me hours to get that thing back to the way it was. But he is right, an allen wrench will loosen it up enough for you to slide it up and off. That is how I tightened mine anyway..
What doesn't kill us only makes us stronger, unless we end up comatose. In which case we slowly degenerate into a shell of what we used to be.
Old 07-11-2010, 02:56 AM
silvermist's Avatar
silvermist silvermist is offline
Vehicle: 08 dodge ram quad cab 1500 4x4
Trim Level: sport
Color: sunburst orange
Rep:37
silvermist is on a distinguished road
when you put it back on make sure it is down far enough. I removed mine and didn't install it right and it kept moving, I thought the back of the mirror was loose untill I moved it one day and saw the plastic near the window move so i loosened the screw and slid it down more and tightened teh screw and it is a torx screw not an allen head, a t25 i believe.
Old 07-13-2010, 01:14 PM
inkdemon's Avatar
inkdemon inkdemon is offline
Vehicle: 2015 Dodge 1500
Color: Vivid black
Rep:37
inkdemon is on a distinguished road
Send a message via AIM to inkdemon Send a message via Yahoo to inkdemon
Sometimes the metal plate has a divot in it that the screw sets on. THis way no moving around after snug.
