Old 07-10-2010, 02:13 AM
simply2cool's Avatar
simply2cool simply2cool is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: Quad Cab SLT BigHorn
Color: Brilliant Black Pearl
Rep:44
simply2cool is on a distinguished road
Default My 2007 MYGIG install
This is my MYGIG istall on my 2007 1500 Big Horn. I replaced my REF Head Unit with a RER MYGIG. Hopefully this gives some information to anyone wanting to do this upgrade.
Components purchased from ebay and coastaletech. Here is a list of components that I used for the install.
RER MYGIG Head Unit LOW SPEED
MYGIG Lockpick Adapter install.pdf
MYGIG Michrophone
Dodge REC Radio Bezel
Radio Filler Bezel
RER GPS Antenna
Sirius Extension Cable (1.4 meters)
Apple Composite AV Cable
Plan 1-2 hours for your install.
First you have to remove two phillips head screws located in the green circles. Then pull off the radio bezel, this may difficult and you may have to pry it a little. I wrapped a screwdriver with foam tape to avoid damage to the dash.
Disconnect 4X4, Heater/AC controls and cigarette and aux power connectors. Then remove radio bezel.
Swap 4X4, Heater/AC controls cubby hole trays to the new bezel using a phillips head screwdriver.
Grey 10 pin connector will not be used on the MYGIG. It is for the external Sirius tuner. The MYGIG has a built in Sirius tuner.
The 10 pin connector on the mygig is used for uconnect Michrophone. It can be purchased at coastaletech. Sorry I forgot to take pics of my michrophone location. I ran it so it barely pokes out in front of instrument cluster, close to the oil temp guage.
The upper dash panel simply lifts off. I used my handy screwdriver wrapped in foam for the initial pry.
I mounted the GPS Antenna in the center speaker location.
Mount the radio in the bottom screw holes.
The filler bezel snaps into the dodge REC bezel.
I mounted the MYGIG Adapter behind the glove box using two side foam tape. The wires tuck nicely in the existing clips.
Run the Sirius Extension cable from the back of the head unit to the passenger kick panel. Plug it into your OEM Sirius antenna.
Run the apple AV cable into the glove box.
Finished Product.
Later I will post the backup camera install.
2007 Ram 1500 Quad Cab, SLT Big Horn, 4.7 Flex Fuel, Volant CAI, Hypertech Max Energy, Westin Nerf Bars, MYGIG upgrade.
Last edited by simply2cool; 07-10-2010 at 02:34 AM. Reason: Forgot important information regarding the head unit
Old 07-10-2010, 02:25 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Excellent write up on the install.
Brian:
Old 07-10-2010, 02:33 AM
Rep:44
Thanks I had to piece together the puzzle from several different forums and websites. Just wanted help out others.
Old 07-10-2010, 11:29 PM
Rep:1625
Excellent write up!
Old 07-11-2010, 12:01 AM
Nice work! I put my GPS antenna in the same place when I upgraded to the REC NAV unit.
Old 07-11-2010, 12:05 AM
Nice write up . That looks great . Little rep for ya .
Old 07-22-2010, 09:16 PM
BeBeep's Avatar
BeBeep BeBeep is offline
Vehicle: 2010 Ram
Trim Level: R/T
Rep:16
BeBeep is on a distinguished road
Great write-up, I followed it like a road map in doing mine.
2010 Ram R/T - 2011 GWE Challenger SRT8
Old 07-22-2010, 09:30 PM
BeBeep's Avatar
Vehicle: 2010 Ram
Trim Level: R/T
Rep:16
I have one question, what is the part number or where can I get Sirius Extension Cable (1.4 meters)? That is all I lack to be complete.
Thank You,
Bob
Old 07-22-2010, 09:37 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
That was a great install and set of pics, thanks for sharing that. Reps all the way.
Old 07-23-2010, 02:07 AM
Rep:44
Thank You,
Bob
This is what took me the longest to figure out and hardest to find. Here is the ebay link for the cable that I bought. You could also use a shorter cable by pluging it into the sirius tuner behind your glove box. Make sure you get a Fakra K Radio IF color curry male-female extension cable. Here is a link to help guide you with the connectors. www.pasternack.com sells the cables (FAKRA Straight Jack To FAKRA Straight Plug; PE-C100 Coax; Key Code K) Part number PE38748K-XX (XX represents length in inches) but they require a $50 minimum purchase.
I hope this helps.
