Not sure why I thought this, but I could swear we had 3" in, dual 3" out. But when measuring, it looks like we have 3" in, dual 2 1/2" out. Can anyone confirm this? Looking to snag one of these to replace the stock muffler:
Just wanted to check in with you on your Mufflex 14" muffler and if you still like the sound after living with it for a while. Is it too agressive or does it have interior drone when the MDS kicks in? From your video it doesn't sound too bad.
I assume you left in your stock tail pipes and resonators.
Thanks for your feedback as I am looking into replacing the stock muffler on my 2011 R/T RAM. Also looking at the Hooker
lol, the exhaust pipe on our trucks in stock form if iam right is 3" pipe to dull
2 1/4" exhaust pipes, and headers do help and so will x pipe when i put it on after i install all the lowering stuff.
Let me rephrase this. Are headers worth it if I am going forced induction? I won't need the extra power, and the exhaust will be turbulence reduced when I am done.
Magnaflow Stainless Steel Catback Exhaust 16869 Muffler and both exits, tips. About 666 ebay. Service Mgr up at Huffines Dodge Plano, TX has a set installed. Not bad.
Magnaflow specs out of the book --
Material: 100% Stainless Steel
Tubing O.D. Size: 3/2.5in.
System Type: Cat-Back
TIP O.D. Size: 5in.
TIP Quantity: 2
Single/Dual: Dual
Exit Position: Dual Split Rear Exit
Features and Benefits: Lifetime Warranty, Dyno Tested And Proven To Make Power, Performance Gains In Horsepower And Torque, Great Sound -Has A Smooth; Deep Tone, Easy To Install, Mandrel-Bent. All Welded. Built To Last.
V8 5.7L Standard Cab/Quad Cab/Crew Cab, Short Bed, with Factory Duals
5 x 11 x 22in. Dual Outlet Muffler, 3/2.5in System, Dual 5in. Polished Tips, DUAL SPLIT REAR EXIT
iam looking to do a full custom exhaust. no body has what i want. coming back from the headers i want an x pipe then two resonators and continue the dull 2 3/4" piping back over the axel and 2 more resonators and out with 4 or 5" tips.
Am I missing something? Some threads say that the exhaust size is 3"-2.5".
And others say that its 3"-2.25". Is it different on the R/T? Hate to order the wrong one...
Related Threads
DODGE RAM FORUM
2.2M posts
201.9K members
Since 2008
We’re the ultimate Dodge RAM forum to talk about the RAM 1500, 2500 and 3500 including the Cummins powered models.
