tonneaucovered.com
Old 07-24-2010, 04:51 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default Not sure about your pipe size?
lol, the exhaust pipe on our trucks in stock form if iam right is 3" pipe to dull
2 1/4" exhaust pipes, and headers do help and so will x pipe when i put it on after i install all the lowering stuff.
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 07-24-2010, 05:29 PM
Vectors2Final Vectors2Final is offline
Vehicle: 2010 Dodge Ram R/T
Trim Level: R/T
Vectors2Final is on a distinguished road
Let me rephrase this. Are headers worth it if I am going forced induction? I won't need the extra power, and the exhaust will be turbulence reduced when I am done.
Old 07-26-2010, 08:13 AM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default headers on ram
Its a must, even more so with a supercharger or turbo. You dont want any restrictions. These stock headers will hold you back from greatness!!!!
Old 07-26-2010, 10:47 PM
Trim Level: R/T
How much were yours?
Old 07-27-2010, 04:15 PM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default cost for headers?
they were 1500. worth it!
Old 07-27-2010, 05:01 PM
09 RT RAM's Avatar
09 RT RAM 09 RT RAM is offline
Rep:39
09 RT RAM is on a distinguished road
Magnaflow Stainless Steel Catback Exhaust 16869 Muffler and both exits, tips. About 666 ebay. Service Mgr up at Huffines Dodge Plano, TX has a set installed. Not bad.
Magnaflow specs out of the book --
Material: 100% Stainless Steel
Tubing O.D. Size: 3/2.5in.
System Type: Cat-Back
TIP O.D. Size: 5in.
TIP Quantity: 2
Single/Dual: Dual
Exit Position: Dual Split Rear Exit
Features and Benefits: Lifetime Warranty, Dyno Tested And Proven To Make Power, Performance Gains In Horsepower And Torque, Great Sound -Has A Smooth; Deep Tone, Easy To Install, Mandrel-Bent. All Welded. Built To Last.
V8 5.7L Standard Cab/Quad Cab/Crew Cab, Short Bed, with Factory Duals
5 x 11 x 22in. Dual Outlet Muffler, 3/2.5in System, Dual 5in. Polished Tips, DUAL SPLIT REAR EXIT
Old 07-28-2010, 02:23 PM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default ram rt exhaust upgrade
iam looking to do a full custom exhaust. no body has what i want. coming back from the headers i want an x pipe then two resonators and continue the dull 2 3/4" piping back over the axel and 2 more resonators and out with 4 or 5" tips.
Old 03-21-2011, 11:59 PM
ramair18's Avatar
ramair18 ramair18 is offline
RAM Rrrrrr/Tttttttt
Vehicle: 2011 RAM 1500
Trim Level: R/T
Rep:64
ramair18 will become famous soon enough
Originally Posted by Blackzilla View Post
Just wanted to check in with you on your Mufflex 14" muffler and if you still like the sound after living with it for a while. Is it too agressive or does it have interior drone when the MDS kicks in? From your video it doesn't sound too bad.
I assume you left in your stock tail pipes and resonators.
Thanks for your feedback as I am looking into replacing the stock muffler on my 2011 R/T RAM. Also looking at the Hooker
RAM 1500 R/T - 2011
Magnum SRT8 - 2006 w/426 boosted
Pontiac Trans Ams - '69, '71, '99 Firehawk
Old 03-22-2011, 08:29 PM
Jimbob's Avatar
Jimbob Jimbob is offline
Vehicle: 2011 Ram
Trim Level: R/T
Rep:22
Jimbob is on a distinguished road
Am I missing something? Some threads say that the exhaust size is 3"-2.5".
And others say that its 3"-2.25". Is it different on the R/T? Hate to order the wrong one...
