Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-10-2010, 06:39 PM
camoman1966's Avatar
camoman1966 camoman1966 is offline
Vehicle: 2006 Ram 3500
Trim Level: Quad Cab SLT 4X4
Color: Dark Grey
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
camoman1966 is on a distinguished road
Default Turbo Problem???
I am driving from Dallas to Boston over the past couple of days, and its raining pretty hard, I go to pass someone and a hear a noise and then the check engine light comes on and I have no power. I tried it several times and still nothing, not enough to pass and barely enough to get on the freeway. It still had power enough to get to crusing speed, but just fell flat if I tried to accellerate. I tried it a couple hundred miles down the road and it seems to be working intermittently now. My first thought is a turbocharger problem, any ideas? If it is the turbo, do they make kits to rebuild these things or am I stuck buying a new one?
Old 07-10-2010, 07:12 PM
iRESQu iRESQu is offline
Rep:2217
Have you thrown any codes? I don't know about rebuild kits, but someone with more knowledge will chime in.
Old 07-10-2010, 08:13 PM
Sounds like it may of been the turbo . Do you have a boost guage ? If so is it making boost ?
Old 07-11-2010, 10:09 AM
Color: Dark Grey
I haven't pulled the codes yet, I'm in Boston at school and probably won't be able to get it done until I leave in a couple of weeks. Also, it doesn't have a boost gauge but it does feel like it is boosting intermittently.
Old 07-11-2010, 10:20 AM
Rep:1890
Get the codes pulled first and foremost.
Old 07-11-2010, 12:29 PM
Color: Dark Grey
Yeah, I'm definately going to do that before I start throwing parts at it. I was just wondering if this was a common problem, I've never owned a diesel.
Old 07-11-2010, 01:01 PM
One of the most important things with a turbo vehicle is when coming off the road from a sustained speed "just don't shut it down" . You need to let it idle for several minutes . It helps to slow down the turbo and give it a cool down period . For those who just like to get out of their car , theres turbo timers that you can install . It lets the vehicle continue to idle for a pre-determined amount of time after you have exited the vehicle . I kept that in mind when I owned a turbo car and got 200,000 miles out of the original turbo before I scrapped the car .
Old 07-11-2010, 04:40 PM
Color: Dark Grey
Thanks, I will keep that in mind. I have just been turning it off.
Old 07-11-2010, 04:42 PM
Rep:1890
The military has a rule of idling all diesel and turbine engines for 2 minutes before shutting down an engine. Aside from cooling the turbo, it also prevents the injector nozzles from coking.
Old 07-11-2010, 10:52 PM
Color: Dark Grey
Hahaha, we must be in two different military's then, I have been in 11 years and never seen anyone keep one running after driving. It's a good idea though and I will be doing it from now on.
