Old 07-10-2010, 10:09 PM
MSPTNY02's Avatar
MSPTNY02 MSPTNY02 is offline
Vehicle: 2010 Ram 1500
Color: Mango
Rep:14
MSPTNY02 is on a distinguished road
Default Removing tail lights
how do we remove our tail lights? i know there are the two torx screws but then what next? it seems you have to pull outwards perpendicular to the length of the truck but im not sure.
Old 07-10-2010, 11:33 PM
Sounds right. If there are only two screws, and they are out, the tails should come straight out towards the back.
Old 07-10-2010, 11:47 PM
MSPTNY02's Avatar
Color: Mango
Rep:14
but they dont. the one clip i can see in there is going inward from the outer part of the light and i dont want to pull and break something so i aborted my mission.
Old 07-10-2010, 11:49 PM
hmmm...mine slip right out after I remove the screws on the side.
Have you tried pulling out from the bottom first and tip them out?
Old 07-11-2010, 12:10 AM
With it being new and freshly assembled , sometimes they just need a little persuasion .
Old 07-11-2010, 12:27 AM
MSPTNY02's Avatar
Color: Mango
Rep:14
yeah i was hoping someone on here had already done it so i dont break something. but if i did it might not be bad. i could use the broken one as my test light for some strobes
Old 07-11-2010, 12:30 AM
I've got to remove the L/R tail light on my '01 tomorrow . I'll pay attention to any tricks I need to do . It can't be much different .
Old 07-11-2010, 02:54 AM
Win's Avatar
Win Win is offline
Rep:99
Win will become famous soon enough
Yep, It just pulls straight back. Eat your wheaties :P J/k.
Old 07-11-2010, 03:29 AM
Rep:4072
Mine was difficult to remove the first time as well when I was installing my backup alarm, but Tom's right, just needs a little persuasion, but it should pull straight out.
Old 07-11-2010, 10:07 AM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
Persuasion. If necessary find a thinnish piece of plastic and pry the tail light housing back to pop the retainers loose. I used one of those putty knife looking things you use to wipe wallpaper flat. I imagine a plastic spatula, etc will work too. The plastic pry bar won't scratch your paint and the retainer will pop loose before anything breaks.
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
