Old 07-11-2010, 03:59 AM
jeff pearson jeff pearson is offline
Vehicle: 04 Ram 1500 Quad Cab SLT
Color: Gold
jeff pearson is on a distinguished road
Default Help reinstalling cap & wires 1995 5.9l please
My friend just tried to replace cap,plugs , wires and rotor.
Took them all off and can't remrmber how to put back on. I tried to help
by starting with post marked with "1" to cyl #1 then clockwise through
the firing order . Still won't start . Any ideas?
rotation is clockwise right?
firing order goes 1-8-....right?
Post on cap marked with "1" is #1 post right?
Old 07-11-2010, 04:30 AM
Rep:4072
It is a clockwise rotation and the firing order is 1-8-4-3-6-5-7-2, not sequential 1-8. Hope this helps some.
Old 07-11-2010, 05:07 AM
Rep:1885
Old 07-11-2010, 06:08 AM
Color: Gold
Thank you for the help. Turns out he put the cap on 180deg out(reversed). When I removed it to check the rotor, only 30 min. old, felt plastic schrapnell scattered around inside of distributor. Rotor had been grinding inside of cap, 30 min new. When I inspected rotor, metal contact piece had been rotated 90 deg from normal from impacting on post pin contacts. A few drops of crazy glue, a blast from air in a can, one minute with a permanent marker to mark everything and it fired right up!
Time to go to sleep, nite all.
Old 07-11-2010, 06:20 AM
Rep:4072
Great, glad to hear you got it going!
Old 07-11-2010, 12:44 PM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
How in the H#@$ can you even work on the distributor on these things? cut a hole in the firewall?? geez! good luck . here is a link for properly routing the plug wires. common misfire problems can be linked to cross firing . http://autorepair.about.com/cs/faqs/l/bl654h.htm
Old 07-11-2010, 12:48 PM
Sounds like he had the distributor cap forced on . They will only seat in one location . Glad you got it fixed . Now you can bail him out the next time he screws up .
Old 07-11-2010, 01:04 PM
Rep:1885
The easiest way is with the intake off; that's why I always recommend replacing the cap, rotor and wires when changing the plenum pan gasket. There's a copy of the TSB relating to the routing in the Knowledge Base.
Old 08-01-2010, 07:11 PM
Color: Gold
Thanks guys...
