Old 07-11-2010, 04:03 PM
supersonic's Avatar
supersonic supersonic is offline
Vehicle: 2007 Hemi Ram
supersonic is on a distinguished road
Default Hemi is hard to start sometimes
My 2007 Hemi ram runs great, and starts right up most of the time. Every ten starts or so it will crank for about 5-10 second before it will start for some reason. A couple of months ago it shut off and i had a hard time getting it to start, but it hasn't shut off on me since then. Any idea what could be causing this? Thanks
Old 07-11-2010, 04:07 PM
Welcome to the forum.
I'd start with a throttle body cleaning and check your fuel pressure as well.
Old 07-11-2010, 04:08 PM
Rep:1877
Dirty throttle body is a likely suspect. Give it a good cleaning. http://www.ramforumz.com/showthread.php?t=46764
Old 07-11-2010, 04:13 PM
supersonic's Avatar
thanks guys, i will give that a try right now!
Old 07-11-2010, 04:17 PM
Have fun! Let us know how it goes.
Old 07-11-2010, 04:39 PM
MoparMadness08's Avatar
MoparMadness08 MoparMadness08 is offline
Vehicle: 2008 Dodge Ram
Color: Cool Vanilla
Rep:63
MoparMadness08 will become famous soon enough
Ive had the same problem but mines done it since i bought it new. ive only got 18,000 on it so i dont think its dirty and it did do it when it was new. curious to see what you figure out.
DSP 91 Oct Tune, BFI Intake, 14" Magnaflow, 180 Stat, Lund Genesis Tonneau cover, Recon LED light bar, Rocky Mtn ATS 305/55/20,
Old 07-11-2010, 07:30 PM
supersonic's Avatar
I got the throttle body all cleaned up, i will let you know later this week if it cured the problem. Just for future ref. how would i check the fuel pressure on this truck? I've never done that with fuel injection before. Thanks
Old 07-11-2010, 07:32 PM
Rep:1877
Attach a fuel pressure gauge to the fuel line or on the fuel rail depending on what type setup you have. Once it's hooked up, activate the pump.
Old 07-12-2010, 06:52 PM
CHILLZ HEMI's Avatar
CHILLZ HEMI CHILLZ HEMI is offline
Vehicle: 2008 Dodge Ram 5.7L HEMI
Trim Level: Big Horn, Quad Cab
Rep:47
CHILLZ HEMI is on a distinguished road
Send a message via AIM to CHILLZ HEMI
I would clean the TB and run a legit fuel system cleaning...
Old 07-12-2010, 08:20 PM
ScatPak07's Avatar
Rep:970
I know this may sound stupid but it happens to me sometimes as well. If you park for a while on a slight slope the gas sits away from the outlet and does not get to the motor effectively. I park like that at home and when I have a low tank of gas it happens to me.
