Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Dodge Ram Decals
Old 07-11-2010, 03:58 PM
rcbazak@yahoo.ca rcbazak@yahoo.ca is offline
rcbazak@yahoo.ca is on a distinguished road
Default 03 electric fuel pump keeps running
Hi there , i have replaced the in tank electric fuel pump and at times it will keep running with the key off ,,also the wire harness was rewired because one was not on the shelf ,,any one gone this way before and what was the fix. Thanks guys
Old 07-11-2010, 04:11 PM
Resident Technician
Rep:1915
Probably a sticking relay. Rewired which part of the harness because what wasn't on the shelf?
Old 07-11-2010, 04:42 PM
Thanks for the reply Randy, i didnt do the work myself but the connector end on the pump was corroded and the wires were worn almost through a ways back,,Question i unplugged all the fuses and relays in the fuse box under the hood is there any other place for relays to look Thanks again
Old 07-11-2010, 04:43 PM
Resident Technician
Rep:1915
My mistake on your truck. The lift pump is controlled directly from the ECM. If everything is wired correctly, then you probably have an ECM going bad.
Old 07-11-2010, 04:47 PM
Whats an ecm and how much do they cost
Old 07-11-2010, 05:01 PM
Rep:4206
Welcome to the forum! I moved your thread over here, that way, others who may be having the same issue will be able to find the info they need on their techincal question as well, but good luck with that, Randy is definitely the man to help!
Old 07-11-2010, 05:08 PM
Thanks cajun still figuring this on line thing out
Old 07-11-2010, 05:09 PM
ECM = Electronic Control Module. Basically, your truck computer.
Old 07-11-2010, 06:27 PM
Resident Technician
Rep:1915
Engine Control Module in Ram trucks with diesel engines.
