Old 07-11-2010, 06:03 PM
MIKIE1954 MIKIE1954 is offline
MIKIE1954 is on a distinguished road
Question cold & hot ac
MY daughter has a 2003 1ton duely, duel cab with a cummins engine.THE problem it is having is the air cond. blows cold on drivers side, but worm on passengers side,what is the matter with it and is this something that I can fix?SHE is in collage and uses it to pull a 5 horse trailer, so far it's been a very good truck,lots of power & good milage. thanks in advance mike
Old 07-11-2010, 06:22 PM
It means getting into the dash and fixing the blend door, Mike.
Old 07-11-2010, 11:31 PM
Ok now how do you get into the dash and whats a blend door?is there somewere i can get the vinfo on doing this? Thanks mike
Old 07-11-2010, 11:48 PM
Rep:1885
Not to be offensive but you probably need to look into professional help for this repair.
Old 07-11-2010, 11:54 PM
Thanks that the info i needed
Old 07-17-2010, 05:31 PM
Thumbs down
I came here looking for help, insted i got go look for someone else to do the repare.i don't like being talked down to and do take offence! At lest give resonse for takeing it to " pro help". No need to reply to this as i wont be back to a place i do not feel will be of any help . Mike
Old 07-26-2010, 12:11 AM
niko2831 niko2831 is offline
niko2831 is on a distinguished road
Mike this happened to me and I had to take my truck to the dealer. The problem is a 10 dollar part, however they have to take apart the steering colum, and whole dash to get to the stupid part. I had an 02 ram at the time and it cost 800 dollars at the dealer. Living in vegas I needed to have A/C. Sorry bro!
Old 07-26-2010, 12:46 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
He's saying to take it to pro help because its a PITA and if you don't know what your doing, then none of your HVAC stuff will work once you're done, therefore, just trying to save you from a bigger headache in th end.
Also, bud...just a hint...if you would have came back and said, "No offence taken, but, i still feel confident enough to tackle this," then I'm sure someone would have helped you. But, if you're going to be an ass, you'll be treated like an ass, and, now, I can guarentee you won't get any help here.
And, just so you know...Randy is a professional and is probably telling you that because its something he probably doesn't even like doing as anything behind the dash sucks and takes a lot of time.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 11-07-2010, 01:02 AM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2006 RAM 3500; 2010 RAM 1500
Color: Black 2 tone grey
Rep:48
rsg1963 is on a distinguished road
Default Same issue
Problem for me was not doors or anything in the dash. Get this; I went to get my compressor replaced this summer and when they replaced it and filled it back up with freon, it only blew cold out the drivers side two vents, and the passengers side was warmer. So they told me to go to Dodge and get a code cleared. Well, I did go to Dodge. They promptly took my $158 and said "your accumulator is leaking, fix that and we can move forward, but that will probably fix your problem" I was not convinced as this made ZERO sence to me. Anyway, I went back to the original shop and they fixed the accumulator. IT FRIGGIN WORKED! No problen since they did that and it's been 3 months. So...make sure your parts aren't-a-leaking and the system is fully charged before you tear into that complicated dash with multiple doors and such. (BTW, the original mechanic refunded my money I spent at Dodge) Good luck!
RAM Pickup: 2010 1500 Laramie Hemi: Magtec Rear Diff cover/AmsOil 75w-110 Syn, 24" Magnaflow, Resonator delete, Line-X; Bilstein shocks with leveling kit 2.75";305/60-20 GY Wrangler Silent Armor Pro Grades; Lift Air Bag Suspension;
RAM Truck: 2006 3500 ST Cummins:Line-X; Leveling Kit 2" with Edelbrock shocks; Ultra Custom rims w/ 265/70-17 Goodyear Silent Armor Pro Grade; Backup Camera/NAV/DVD video/Reese 24K 5th wheel hitch; RDS 51 Gal tank/toolbox; Banks:CAI, MonsterRam 3.5",Monster Exhaust;Pac Brake Prxb.
