Old 07-12-2010, 09:04 PM
Halifax's Avatar
Halifax Halifax is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT 4X4
Halifax is on a distinguished road
Default tow/haul or o/d off?
Just curious what everyone uses while driving around town (city driving 30-70km/h) and how fast is too fast to be driving with o/d off?
Old 07-12-2010, 09:49 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
o/d is primarily for economy at hiway speeds, 88kph or 55mph in the US. Not using it will not hurt the truck at all until you get into the high speeds 80mph or more most likely. At those speeds you'd be putting a lot of stress on the motor. Key is the rpms, watch your tach.
Brian:
Old 07-12-2010, 10:17 PM
Halifax's Avatar
Trim Level: SLT 4X4
thanks for the input. someone had told me it's hard on the transmission driving around town with the o/d on, always shifting in and out of overdrive. any truth to that?
Old 07-12-2010, 11:14 PM
Yeah, the trans will slip a bit in O/D when driving at low speeds around town, and it goes in and out of O/D with the slightest throttle input.
I don't use mine until I hit freeway speeds and leave it in O/D off mode until I hit those speeds.
Old 07-12-2010, 11:27 PM
Halifax's Avatar
Trim Level: SLT 4X4
thanks for the help guys. Maddog whats the offset of your rims? They give your truck a nice stance.
Old 07-13-2010, 02:28 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
you can use tow haul why don't you just leave way it is?
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 07-13-2010, 02:48 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
What rim/tire do you have and what gears are you running? At those low speeds I don't think your transmission will be doing much gear hunting. Maybe if you do a lot a light throttle to heavy throttle.
At 70km/h (44mph) don't think you will getting into O/D (5th gear). If you have the 20" wheels and a 3.55 then your rpms would be 1060 in 5th gear.
At 60km/h (37.5mph) you def won't be in O/D because your rpms would be 908.
Again, my assumptions are with the 20" wheel and a 3.55 gear.
Maybe someone that knows about the transmission programming and/or shifting will be able to help out some more. But as already stated, you won't hurt anything drving with o/d off at those speeds.
Old 07-13-2010, 01:58 PM
PimpJuice's Avatar
PimpJuice PimpJuice is offline
Vehicle: 2007 Dodge Ram 1500
Color: Blue
Rep:150
PimpJuice has a spectacular aura aboutPimpJuice has a spectacular aura about
Ive been curious about this too. Ive always drove with O/D on (i think so cause there no lights on the dash on) wether im goinin 25mph or 80mph. Do i need to start pushing the button and putting it in O/D OFF?
Old 07-13-2010, 06:23 PM
Rep:2616
if i'm going up or down a hill, 6% grade & i'm behind a heavy semi, i manually shift my tranny, i use 2nd gear a lot here.
manual shifting an automatic doesn't hurt it, so if your in town, you can shift it manually, on my dash read out, it can read:
1, 2, 3, 4, 5, & then the gear read out disappears, the transmission now shifts to any gear it needs to, including O/D.
O/D doesn't kick in when a gear is displayed on the read out, i don't know about older Rams
Old 07-13-2010, 07:51 PM
Halifax's Avatar
Trim Level: SLT 4X4
20" rim 275 60 tire. not sure of the gearing I've only had the truck about a month and I'm not sure how to find out the gearing. Call the dealer with vin?
