Old 07-12-2010, 09:19 PM
lonewolf lonewolf is offline
lonewolf is on a distinguished road
Default trailer wiring
i have a 2003 ram 1500 factory trailer wireing. problem is no left turn signal or left brake lite at trailer plugs truck tail lite turn and brake works fine help please
Old 07-12-2010, 09:21 PM
Rep:1885
Check the fuse yet?
Old 07-12-2010, 10:47 PM
trailer lites right turn and brake lites work fine would there be a seperate fuse for left side
Old 07-12-2010, 10:49 PM
Rep:1885
Yup. Dig around in the IPM under the hood and you'll probably find a blown fuse.
Old 07-13-2010, 11:38 PM
just checked all fuses ok any other ideas thanks for your help so far dont know where to go next
Old 07-13-2010, 11:40 PM
Check for power at all trailer plug terminals off the truck.
Then check continuity between the trailer plug and the lights at the back end.
Old 07-13-2010, 11:50 PM
ill try that tomoro thanks again
Old 07-13-2010, 11:51 PM
Good luck and let us know how it goes!
Old 07-14-2010, 03:38 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Have you verified that the pin in the trailer connector is OK. Have you checked the connector on the back of trailer connector? Have you checked for power at the connector with a meter or test light or trailer connector tester?
The left turn pin is the one on the extreme left when looking into the connector.....I think it's even labeled on the outside of the cover (if it's OEM).
Are you sure the fuse is good.? Should be Fuse 46 (15A). If yes, when the left signal is on, can you hear a clicking from a relay in the IPM.
If no, you might have a bad relay (unlikely) or a bad FCM (Front Control Module).
If yes....just replace the fuse (46) just to be 100% sure. Else it is likely a wiring issue between the IPM and trailer connector.
brad
Interested in one of my mods?
Old 07-17-2010, 09:49 AM
Default newbie
i hope im doing this right.... i have a 2003 ram 1500 with factory tow harness truck running lites,brake lites,turn signals and four ways all work fine.......... but at the trailer plugs ie 7 pin---4 prong no left turn or left brake. what should i look for, or simply blow it up....
