2010 Dodge Ram 2500 TRX4 Leveling Questions.. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-12-2010, 10:53 PM
Powerback73's Avatar
Powerback73 Powerback73 is offline
Vehicle: 2010 Dodge Ram 2500
Trim Level: TRX4
Color: Black with Grey Trim
Rep:58
Powerback73 will become famous soon enough
Default 2010 Dodge Ram 2500 TRX4 Leveling Questions..
Ive been reading on some threads here that leveing a TRX4 will mess up the suspension....but no one ever said why.... Im thinking of geting a Hell Bent Steel 2.5" leveling kit. the kit comes with the anit-sway bar brackets to return them to there stock location. I plan on running some 35" Mickey Thompson MTZ but you people got me all paraniod bout doing that...Sooo whats so bad about leveing out my truck...
Old 07-13-2010, 01:29 AM
gtfloyd's Avatar
gtfloyd gtfloyd is offline
Vehicle: 2008 Ram 2500 4X4
Color: WHITE
Rep:21
gtfloyd is on a distinguished road
I had no idea they make a 3/4 ton TRX4! Guess who is getting stickers for their bed?
What doesn't kill us only makes us stronger, unless we end up comatose. In which case we slowly degenerate into a shell of what we used to be.
Old 07-13-2010, 01:36 PM
Rep:1625
Someone asked this question a while back, but nobody had an answer. There is an explanation in this thread, but it refers to the 1500s:
http://www.ramforumz.com/showthread.php?t=52969
Old 07-13-2010, 09:08 PM
Trim Level: TRX4
Rep:58
Ive read that thread, are those problems just related to the 1500? I wish someone with a 2010 2500 would chime in on there leveling experience...
Old 07-13-2010, 09:15 PM
Rep:1625
I know of only one other member with a truck like yours on here and he wants to know the same thing.
Old 07-17-2010, 11:48 PM
ttontis's Avatar
ttontis ttontis is offline
Trim Level: TRX Crew
ttontis is on a distinguished road
I have been holding off ordering my leveling kit until I can find an answer. I sent a request to skyjacker to ask and I didnt get a response back. I do not think the fact they didnt answer means anything but I do not want to install it, take it in for an alignment to find out I have to take it off and get another alignment once I take it back to the stock level.
Old 07-20-2010, 10:37 PM
Trim Level: TRX4
Rep:58
Just ordered a leveling kit from KORE. Set me back $399 plus 117 for shipping. Its gonna take a while for it to get here tho...errrr....Works with the TRX4 2500 models. Ill be sure to post pics when it gets installed. I dont expect it anytime soon tho...they said 10-14 day to ship after they get the payment. Oh well im gonna get my exhaust put on tomorrow Cherry Bomb Extreme duals.
Old 07-20-2010, 11:06 PM
Rep:1625
Sounds good man, good luck with everything
Old 07-21-2010, 01:41 AM
Jacqson Jacqson is offline
Vehicle: 2011 Ram
Jacqson is on a distinguished road
IMHO, A lot of companies make leveling kits but only a few make kits that don't screw up your truck. Carli Suspension makes an excellent kit for your truck and you can ask them any questions before you buy it so as not to have any problems after it is installed. Give them a call and pose this same question to them. They will let you know if there will be any problems with what you are trying to achieve with your truck. Here is a pic of their leveling kit. To me it's a bit pricey, but if you want quality with no problems and good customer support then it may be worth it to you to buy it.
http://www.thecarlisuspension.com/do...velingkit.html
Old 07-21-2010, 03:49 AM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
You should be able to run a leveling kit on the front of a 2500 trx no problem. As previously stated I would consider either kore or carli if you want to go the spring route. If you want to use a spacer I would contact topguncustomz or rize ind. These company's all make a fine product you cannot go wrong with. Upgrade the shocks (to a dual or tower set up with a nice set of reservoir shocks) and you will have one mean ride!
SUL73NAZ
