Old 07-13-2010, 12:23 PM
nitrofish640 nitrofish640 is offline
nitrofish640 is on a distinguished road
Default 1998 ram overdrive light wiring circuit
any have a link to a wiring schematic the orange wire with the white stripe from pcm to shifter button is neg and should be + than everything changes color and not sure where it goes manual on the way but its going to be a week
Old 07-13-2010, 01:37 PM
Rep:1877
It's going to show up as a ground if the PCM connector is still hooked up. The other wire goes straight to ground and you should have continuity there.
Old 07-13-2010, 08:25 PM
my other ram shows + on the orange white striped wire closest to fender on pcm to switch on shifter fo overdrive disengage. and it works fine
Old 07-13-2010, 08:35 PM
Rep:1877
Knock yourself out, man. I'm not going to beg you to take my advice.
