Tpms - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-13-2010, 05:20 PM
MSPTNY02's Avatar
MSPTNY02 MSPTNY02 is offline
Vehicle: 2010 Ram 1500
Color: Mango
Rep:14
MSPTNY02 is on a distinguished road
Default Tpms
ive been having an intermittent message that my right rear wheel is not registering any pressure despite it looking fine. it doesnt happen all the time but it does occur. any thoughts as to why? i have the hid's in and ive read b4 that they can interfere with the tpms but does the rears communicate with the fronts and then send the signal? i have my first oil change coming up so i was going to have them check but any thoughts until then?
Old 07-13-2010, 05:24 PM
HID's and TPMS are not connected in anyway. A TPMS sensor in the wheel can fail as can the receiver end of the sensor affixed to the vehicle. I suspect one or the other has an intermittent problem.
Check the harness and make sure the connections are tight as well.
Old 07-13-2010, 06:12 PM
MSPTNY02's Avatar
Color: Mango
Rep:14
thanks maddog
Old 07-14-2010, 08:45 AM
BigBlueEdge BigBlueEdge is offline
Vehicle: 2017 Ram2500 Laramie Sport 6.4
Rep:20
BigBlueEdge is on a distinguished road
I have the HIDExtra HIDs in lows and fogs. I've noticed that often when I turn the fogs on the tire pressure warning light comes on for a second or two on the dash. It does not stay on. It is definitely related to HIDs though. I suspect that when the HIDs start up they interfere with the RF signals between the tire sensors and the receivers.
Rob
Old 07-14-2010, 12:26 PM
Resident Technician
Rep:1915
Rob
This is a likely scenerio since the sensors communicate with the WIN module in the dash.
Old 07-14-2010, 06:07 PM
MSPTNY02's Avatar
Color: Mango
Rep:14
im thinking it may be a possible link. i notice that if i turn on my hid's when i first turn on the ignition, the tpms sensor has a higher likelihood of going off. if i wait like 30 seconds then turn them on i usually dont have a problem. but im due for my first oil change in a week or two so ill have them check it w/o letting them know of the hid's and see what they come up with. versus them just saying they are causing it.
Old 05-21-2016, 12:20 AM
Toon tugr's Avatar
Toon tugr Toon tugr is offline
Vehicle: 2005 cummins & 2010 5.7 Hemi
Trim Level: 2005 & 2010 are SLT
Color: 2010 Silver, 2005 Burgundy / silver
Toon tugr is on a distinguished road
Where are the TPMS receivers located?
I have had an intermittent RR loss of communication for about a year and have rotated tires a couple times and always right rear losing signal and this week it started doing it almost every day now. Comes and goes. will read for a while and then lose and then register and on it goes, thinking I have a receiver issue but not sure where to look.
Thanks for any input.
05 Cummins 4x4 QC SB 123k,10 Hemi 4x4 QC SB 101k
sold 02 http://www.youtube.com/watch?v=i3TkO071kTk
Old 05-21-2016, 05:50 PM
bee1971's Avatar
bee1971 bee1971 is offline
Vehicle: 2011 Dodge Ram - 1971 Superbee
Trim Level: Sport Quad Cab 4X4
Color: Deep Water
Rep:18
bee1971 is on a distinguished road
Each tire sensor tpms has a battery - Average life of a tpms battery is 5 to 7 years depending on miles
Old 05-23-2016, 02:38 PM
Toon tugr's Avatar
I know about the tire sensors but I am asking where the TPMS receiver module is located on the pickup. I have the right rear that is not picking up even after a couple rotations so pretty much know its not a sensor issue since it stays with that location no matter which tire is rotated into that spot.
