Old 07-13-2010, 06:49 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Default True GPS vs Cellular GPS
I thought some might find this useful.
There are two primary consumer sources of GPS navigation, true GPS and cell phone navigation. I'll list the differences and advantages/disadvantages of each.
True GPS - This system/unit receives its signals from the GPS satellite constellation. The signals do not carry maps or anything other than a locator and timing signal. The timing signal is used for synchronization between the satellites and the ground station controlling them. Your receiver determines where you are by comparing signals from at least 3 satellites. The maps on the receiver and its voice are software/firmware loaded onto the device.
Advantages: Navigation everywhere on earth provided you have the maps for the country you're currently in loaded on your receiver device.
Disadvantages: Map updates need to be purchased for your receiver device occasionally (about every 3 years or so if you do a lot of traveling), this is not cheap ($199.00 on current Ram Nav system). As I said above tall buildings in cities can cause problems. Also, signals do not penetrate well into buildings, underwater, or underground.
Cellular GPS: This is a service you pay for on a monthly basis. You are receiving your GPS signal from your service provider. They receive the GPS signal from the GPS constellation for free. They use the signal for timing synchronization of their cellular receivers and transmitters aka towers.
Advantages: Maps are always up to date with the latest information because your phone receives updates as needed. Works great in urban environments and indoors.
Disadvantages: If you are outside your service provider's network you lose GPS capability. You pay a monthly fee for something that is free. You must have a GPS service compatible phone (not all are). Underground and underwater are still not an option.
Brian:
Old 07-13-2010, 08:25 PM
Rep:1909
No underwater service with either? How am I supposed to get to the Titanic?!
Old 07-13-2010, 08:46 PM
brvheart's Avatar
brvheart brvheart is offline
Vehicle: 2010 Ram 1500 Crew Cab
Color: Mineral Gray
Rep:34
brvheart is on a distinguished road
good info! I think a notable mention is the hybrid - the iphone for example has a GPS antenna built in and I use Navigon on it (have Tom Tom also but Navigon is better imo) and it has done good in the place of a stand alone unit. When GPS signal is scarce it can use cell towers to help triangulate your position.
Old 07-14-2010, 12:09 AM
TRIPOD's Avatar
TRIPOD TRIPOD is offline
Vehicle: 1999 Dodge Ram 1500
Trim Level: id say simple
Rep:64
TRIPOD will become famous soon enough
I know some that down load the application on their phone with a free trial, then when it's expired, they delete it, and down load it again for free.
08 Ram Laramie- Gone but not forgotten
99 Ram- lots of future plans on this one!
Old 07-14-2010, 12:13 AM
Nice and useful info!
Old 07-14-2010, 12:15 AM
Rep:1625
Nice info! Thanks for sharing
Old 07-14-2010, 07:50 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
good info...
not all GPS is created equal... some are more accurate than others. I had one on my phone, that not only told me to go the wrong way, but has also brought be to the wrong location.
I've since bought a true GPS and canceled the cell version.
Exco
Bill
Old 07-14-2010, 08:31 AM
KingBrenton's Avatar
KingBrenton KingBrenton is offline
Vehicle: 2002 Dodge Ram 1500
KingBrenton is on a distinguished road
My HTC Touch Pro2 has true GPS, as do lots of new phones. I used to have Garmin software on it and you wouldn't know the difference between it and a regular Garmin car unit.
