Help Identifying wire. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 07-13-2010, 09:46 PM
aMisfit aMisfit is offline
aMisfit is on a distinguished road
Default Help Identifying wire.
I've got this wire hanging down from under the dash, and I have no idea where it goes. I've looked and looked, but nothing. Heres some pics.
Any ideas?
Old 07-13-2010, 10:54 PM
Looks like something someone has put in there . Doesn't look factory .
Old 07-13-2010, 11:02 PM
Resident Technician
Rep:1915
Agreed. That's not factory.
Old 07-13-2010, 11:33 PM
Someone might have wired in some lights, a programmer or some other accessory (power to a CB maybe?) but that's definitely not factory.
Did you find a termination point at the other end? Does it go to the battery or the fuse box?
Old 07-16-2010, 08:47 AM
It's actually just soldered onto another wire, heres a pic.
Old 07-22-2010, 10:09 PM
RAMIT222 RAMIT222 is offline
Vehicle: 2001 Dodge Ram
Color: White w/blue trim & chrome
RAMIT222 is on a distinguished road
Looks like a power wire for some accessory. If you are not using it I would remove it @ the soldered area & then shrink tube it there. You wouldn't want a bare power wire.
Old 07-22-2010, 10:13 PM
It doesn't even look like it's soldered . It needs to go .
Old 07-22-2010, 10:27 PM
Garbageman's Avatar
Garbageman Garbageman is offline
Vehicle: 2010 1500 ST Quad Cab 4x2
Trim Level: Really cheap
Garbageman is on a distinguished road
Yep, someone added that. I would put liquid tape on the soder joint then cap the live end. You may want to use it later.
