Fake key fob to start truck - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-15-2010, 04:11 PM
dwarner dwarner is offline
Vehicle: 2009 Dodge Ram 1500
Color: Inferno Red
dwarner is on a distinguished road
Originally Posted by Excoastie View Post
I mistakenly picked up the key to the wife's Challenger and tried to start my truck with it. It would turn in the hole without a problem, just nothing happened except the message.
What if you had the correct key in your pocket, and turned the ignition w/ the wrong key? I'm assuming the range of the keys isn't far enough, but it might be a simple test!
Old 07-15-2010, 04:18 PM
UN4GTBL's Avatar
UN4GTBL UN4GTBL is offline
Vehicle: 2007 Dodge Caliber
Rep:41
UN4GTBL is on a distinguished road
if they were on the same key ring would it work i wonder?
2007 Dodge Caliber SXT - 1.8L I4 & 5-Speed Manual
2011 Dodge Grand Caravan SXT Plus - 3.6L V6 & 6-Speed Auto
Wanting a new Ram...
Old 07-15-2010, 04:21 PM
Resident Technician
Rep:1915
Kinda defeats the purpose, doesn't it?
Old 07-15-2010, 04:25 PM
Color: Inferno Red
I imagine that would probably work; but ideally I'm wondering if a small "stub key" could be made to be left in the ignition switch while the real key stays in your pocket.
Old 07-15-2010, 06:16 PM
Resident Technician
Rep:1915
I seriously doubt it because of the range of the WIN system. I can have a key within 18 inches of the WIN module and it wont detect it.
Old 07-16-2010, 08:35 AM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
That wouldnt work the key has to be almost touching the switch for it to read the key..
To be able to start the truck with the key in your pocket first thing you would have to have a keyless go key (not avail. on the ram)they are different than your key they look the same on the outside but inside there very different. then you would have to have a passive entry module which you would have to hardwire into the canbus system and a couple recievers to (see) the kg key then after you have all the hardware in place here comes the software issue and here's where it gets sticky because you cant change the configuration to accept the passive entry module on the network. And no the dealer does not have access to do this I wish we did....
Old 07-16-2010, 10:49 AM
Resident Technician
Rep:1915
Passive entry kicks ass. Too bad it's not offered on the highline Rams.
Old 07-16-2010, 02:12 PM
Trim Level: R/T
Color: Gray
Rep:145
Yes it does we got some 2011 grand cherokee's yestarday with the button on the handle for passive entry its awsome...no more touching the remote....
Old 07-16-2010, 04:55 PM
steelreign's Avatar
steelreign steelreign is offline
Vehicle: 2014 Dodge Ram
Trim Level: Laramie Limited
Rep:70
steelreign will become famous soon enough
I had this on my 2008 Nissan Armada that I traded in. It's really the only thing I miss about the Armada. As long as I had the key fob within 3 feet of the vehicle, I could use the push button on the door handle to unlock the door and start it without putting the key into the ignition. I never had to take my keys out of my pocket. I've had my Ram for 3 weeks and still try to push the door handle button to unlock it and start the truck without the key.
"Battles are sometimes won by Generals; Wars are nearly always won by NCO's and Soldiers"
Old 07-16-2010, 05:07 PM
Resident Technician
Rep:1915
Did you guys not get any of the 300's with it?
