HID problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-14-2010, 01:10 PM
alittlepage24 alittlepage24 is offline
alittlepage24 is on a distinguished road
Default HID problem
I just installed HIDs for the lowbeams and fogs. When i first turn on the truck, they all turn on and then usually one or 2 of them will go out, usually on the driver's side. Once I turn them off and back on, they work just fine. Any way to fix this?
Old 07-14-2010, 01:11 PM
Rep:1625
What brand kit did you go with?
Old 07-14-2010, 01:18 PM
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Rep:4376
First, welcome to the forum, since I see you're new here! Unfortunately, I don't have an answer to your question, but lots of folks on here have installed HID's and had a few problems with them. Since there are way too many posts to quote here, you can look in this section for some ideas until someone comes along that may be able to help: http://www.ramforumz.com/forumdisplay.php?f=78. Also a search of HID's will probably turn up some other ideas as well, but good luck and keep us posted! When you get a chance, be sure to introduce yourself to everyone in the Newbie Checkin and get your official Ram Z welcome!
DDM 35w 8000k
Old 07-14-2010, 01:23 PM
Rep:1625
I know MS520 has the DDM kit also, he may be able to help. Have you tried contacting them and explain your problem?
Old 07-14-2010, 01:25 PM
I sent them an email but they havent responded yet.
Old 07-14-2010, 06:04 PM
MSPTNY02's Avatar
MSPTNY02 MSPTNY02 is offline
Vehicle: 2010 Ram 1500
Color: Mango
Rep:14
MSPTNY02 is on a distinguished road
re-check all of your connections. i have a set from 3bspec and have not had a problem at all. at first my driver side did not come on at all and i re-checked my connections and no problems ever since. not even flashing by other drivers
Old 07-15-2010, 06:31 PM
Well anyway, here's a picture
Old 07-15-2010, 07:04 PM
Rep:1625
They look great, nice and bright
Old 07-15-2010, 07:06 PM
ScatPak07's Avatar
Rep:970
Sounds like a connection if they just go out. If they started to flicker then it may be a ballast problem
