Old 07-14-2010, 10:55 PM
bayboy bayboy is offline
bayboy is on a distinguished road
Originally Posted by Remerson228 View Post
The stat could still be a problem because the 4.7 is so damn hard to bleed the air out of without a lift pump. Are you sure you bled out all the air?
I didn't put the stat back in till like a week later. I know i didn't bleed the air out of the system though. So what is a EGR valve?
Old 07-14-2010, 11:33 PM
Rep:1885
Not bleeding out the air will cause the 4.7 to overheat. Make sure the air is out of the system. If your EGR were at fault, chances are the MIL would be on.
Old 07-14-2010, 11:39 PM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
get your radiator rodded i did this and they found out it was blocked up really bad i had to replace it and now its smooth sailing
if your egr valve is bad it would stall out randomly i had to replace that already and it would throw a check engine light on the dash.
the radiator is what im thinking is the issue i had the same issues with it overheating on the freeway.
the radiator shop will most likely check it for free so u might as well if u catch it soon enough they might be able to rod it
Old 07-14-2010, 11:41 PM
Rep:53
and with the stat out wont it leak?
when i flushed my block i put the hose and fitting back on with out the stat and when i ran water thru it spraye out from between the block and fitting because the seal is on the stat.......
Old 07-15-2010, 06:49 PM
Rep:1885
The seal may have gotten pinched.
