Old 07-15-2010, 12:13 AM
jayhkr's Avatar
jayhkr jayhkr is offline
Vehicle: 2006 Dodge Ram SLT 4x4
Color: Atlantic Pearl Blue Metallic
Rep:75
jayhkr will become famous soon enough
Send a message via ICQ to jayhkr
Default Rattle from break/tire area
Hey all, well earlier this year I replaced my front rotors and brakes. Since then, I've heard this "tink" sound comming from the drivers side front wheel/brake area everytime I hit a bump, big and small. I've taken the wheel off, checked what I could and still nothing. It is definately NOT hindering my brakeing or stopping ability whatsoever and have been dealing with it since March. I was just curious if anyone had any suggestions as to what it could be. The only thing I could think of was the "pins" on each side of the calipers, since I had to keep the originals.
Old 07-15-2010, 07:58 AM
thardy3's Avatar
thardy3 thardy3 is offline
Vehicle: 2004 Ram 1500 2wd
thardy3 is on a distinguished road
It probably isn't the brakes at all.
I would check your wheel bearing/hub assembly, tie-rod ends, and sway bar.
Also, I see you have a 4x4, are your torsion keys cranked up?
2004 Ram 1500, 2wd, Hemi, DJM Lowering Shackles, 18" XD Monsters, 285/65/18 Nitto Terra Grapplers
Old 07-15-2010, 09:18 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
I have a 2003.............I had to replace the front wheel bearings. It sounds like that could be your issue. Jack up the front and spin and grab the tire. Move it around and back and forth to check for play and noise.
Old 07-18-2010, 12:42 PM
jayhkr's Avatar
Rep:75
Thanks guys, I'll check the wheels out. Glad to hear it's really not the breaks, as you can imagine my slight worry. I've never touched the torsion keys so I'd say it's not that. Just never noticed it before I changed out the breaks.
Old 07-18-2010, 12:53 PM
If you did the brakes and hear this noise, make sure your brake lines are properly secured, check the caliper fasteners and generally inspect the area to make sure all items are secure.
Old 07-18-2010, 02:12 PM
Rep:1845
A "tink" sound would indicate some sort of thin/lightweight metal is making contact. Check the calipers for missing or out of place hardware since it seems to be doing it when the brakes are applied and the pads are shifting in the caliper bracket.
Old 07-18-2010, 08:58 PM
mattg1500's Avatar
mattg1500 mattg1500 is offline
Vehicle: 2005 Dodge Ram QC
Rep:22
mattg1500 is on a distinguished road
Check swaybar endlinks and I had a noise like that and it was the inner fender well loose. the bolts were in but not tight, this happened in my dads 05 dakota also
Old 07-21-2010, 11:45 AM
gmag69's Avatar
gmag69 gmag69 is offline
Vehicle: 2007 Dodge ram quad cab
Trim Level: Big Horn edition
Rep:18
gmag69 is on a distinguished road
When you did the brake job did you put the anti rattle clips back in? My '07 made a Ch-CH-CH sound every time I hit a bump. Whoever did the brakes last didn't put the clips back on and the pads were rattling in the holder. Just something to look at.
Old 11-30-2010, 04:28 AM
okami89's Avatar
okami89 okami89 is offline
Vehicle: 02 ram 1500
Color: red
Rep:26
okami89 is on a distinguished road
Take a look at your U joint, I heard a sound like your saying and I thought the same thing but it turned out to be the U joint for me.
Aut Pax Aut Bellum
- Clan Gunn
Old 01-10-2011, 10:09 PM
frenchy's Avatar
frenchy frenchy is offline
Rep:12
frenchy is on a distinguished road
Well it must be too late now but when you go over bumps try to gently put your foot on the brakes just to see if the noise goes away, if it does i bet you it's your pads moving up and down in your caliper, sometimes it happens, you can put some brake pad grease at the top and bottom of each pad (right where it slides into the caliper). If that's your problem, some grease will solve it but when the grease is gone the noise come back so there's another way but it's harder to explain or picture it, it's to hold the pad in the vise and hit it with a punch right on top and bottom (basicly same spot where you can put some grease, where you slide pads) so you spread some of the brake pad material and by doing so prevent pad from moving up and down in the caliper.
