Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-15-2010, 12:47 AM
bcjjones bcjjones is offline
Gender: Not Specified
Rep:13
bcjjones is on a distinguished road
Default Hesitation/Backfiring
Got a single cab 96 dodge ram 1500 5.2. Been having some problems with it being real hesitant when i push the throttle, especially on take off. It's standard and basically if i floor the throttle take of it doesnt do anything at all for a second or so and then starts to pick up and seems not to have very much power. Also it has been backfiring between shifting gears, pretty much every gear shift it'll backfire. I know its not the belly pan gasket because i replaced that. Just did a valve job so basically has all new gasket, also replaced the timing chain and sprockets. Didnt replace the throttle body gasket tho but dont think that has anything to do with it. I'd really appreciate any help, cant stand how hesitant the truck is and the backfiring is getting old. Thanks again.
Old 07-29-2010, 10:58 AM
Lonewolf4858's Avatar
Lonewolf4858 Lonewolf4858 is offline
Vehicle: 1998 Dodge Ram 1500 4X4 EX Cab
Trim Level: Laramie SLT
Lonewolf4858 is on a distinguished road
Send a message via ICQ to Lonewolf4858
Backfire through the intake, ignition timing, backfire through exhaust, valve timing. The other thing could be a restricted exhaust. You can try disconnecting the exhaust pipe either at the manifold or before it goes through the cat and then try driving it.
Old 11-07-2010, 02:33 PM
iamtwarner65's Avatar
iamtwarner65 iamtwarner65 is offline
Vehicle: 2001 dodge ram 1500 5.2
Color: blue
iamtwarner65 is on a distinguished road
had a problem like that code was missfire in number 8 cylinder i removed injector rail and i had look like sand and crap in it cleaned it out and replaced #8 injector run just fine.i will probably have to clean gas tank or it will happen again.
Old 11-09-2010, 03:44 PM
MaxPower1971's Avatar
MaxPower1971 MaxPower1971 is offline
Vehicle: 1993 250--1994 2500--2005 2500
MaxPower1971 is on a distinguished road
Just need to pull out the pre cat o2 sensor for that test.
To the OP, do you get a dummy light?? Check the codes with the on-off switch thing....sometimes a code is stored on the pcm but the CEL is not lit.
MaxPower
