Old 07-15-2010, 12:07 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
Default Thank you, Cajun, wermbang, and Remmerson
thanks and i will rep ya when i can
Cajun, you were right the pcv vale looks bad its covered in oil
wermbang thanks for helping me get the airbox off
and remmerson for telling me i needed to clean the throttle body it looks horrible
thanks again everyone just 2 more questions why is the pcv valve covered in oil? and do i have to use break cleaner in the throttle body? (its the 5.2L v8)
Old 07-15-2010, 02:45 AM
Rep:4085
You're welcome hemi and thanks for the kudos, after all, that's what we're here for! As far as the PCV, granted this is just my experience, it's a sign that there is too much pressure in the crankcase and when that happens, anything under pressure will find the easiest way out, be it into the airbox or the like. That was the case for me and at the time, I was not intuitive enough, lol, to put two and two together and figure out I was getting some classic symptoms of some serious engine problems. Found a lot of it when I did the valve cover gasket.....Needless to say, I am now looking for a new engine.
Old 07-15-2010, 02:58 AM
gtfloyd's Avatar
gtfloyd gtfloyd is offline
Vehicle: 2008 Ram 2500 4X4
Color: WHITE
Rep:21
gtfloyd is on a distinguished road
Upgrade to the 6.1 SRT motor! It rocks well it does in the challenger anyway, could you make an adapter plate for the tranny?
What doesn't kill us only makes us stronger, unless we end up comatose. In which case we slowly degenerate into a shell of what we used to be.
Old 07-15-2010, 03:13 AM
Rep:4085
Heck yeah, the 6.1L would be freakin' awesome! Don't know that I could make that work in place of a 4.0L, though, as it's my '91 Jeep I'm working on.
Old 07-15-2010, 08:19 AM
They make a cleaner specific for carbs and TB's you should use. Any auto parts store would have it.
The PCV valve will be oily because that's what it handles, oil. PCV stands for Positive Crankcase Ventilation and that's what the system does, vent your crankcase. It recirculates airborne oil droplets back to the engine.
Old 07-15-2010, 08:34 AM
Rep:1909
The 42RLE that's in her truck wouldn't last a day behind a Hemi. She's have to go to the 545RFE.
Old 07-15-2010, 09:00 AM
I know they don't make one specifically for a 5.2 , but with some ingenuity you could adapt a catch can and keep all that mess out of the intake and it would help keep your throttle body cleaner .
