Old 07-16-2010, 08:54 AM
stmabe's Avatar
stmabe stmabe is offline
Vehicle: 2001 Dodge Ram Quad Cab
Trim Level: SLT Laramie
Color: Dk. Garnet Red Pearl Coat
stmabe is on a distinguished road
Default Transmission in "Limp Mode"
After a lot of research online it looks as if I need to replace the Control Solenoid and Pressure Solenoid.
According to my build sheet I got from Dodge I have the 46RE with lockup Torque converter. Which means I need on controller with Lockup.
Is there anything else I should look at while I have the pan dropped?
Thanks
Old 07-16-2010, 10:12 AM
Rep:1882
Might as well give it a band adjustment while you're at it.
Old 07-16-2010, 10:18 AM
stmabe's Avatar
How do you adjust the bands? Guess you can tell I haven't messed with Transmissions much.
Old 09-02-2010, 05:28 PM
lst1166's Avatar
lst1166 lst1166 is offline
Vehicle: 2000 quad cab ram (DUKE)
Trim Level: The Dave Jones Trim
Color: silver & flat black
lst1166 is on a distinguished road
I had the old limp mode problem for almost one year. I did everything and I mean everything to fix it nothing worked. until I found a guy that was a dodge mech. and had a shop on the side he fixed it in 2 Hours. Get your self a good set of crimpers. start at the computer and work your way to the trans. re crimp every connection. It cost me a lot of cash and a bunch of grey hairs to find that problem.
Old 09-03-2010, 09:42 AM
stmabe's Avatar
I replaced all the electronics in the Transmission and it has been working great. Knock on wood! Thanks for the information if it acts up again I will check all my connections.
