Closed Thread
Old 09-10-2010, 05:57 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Damn, I knew I forgot something, I forgot to run some numbers for you Michael. Dan, what is the specs on that Focal? I was gonna run the numbers for Michael against a box he was looking at. Damn A.D.D.!
Old 09-10-2010, 06:11 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Here you are sir:
  #93
Old 09-10-2010, 06:13 PM
MADDOG MADDOG is offline
Rep:22
Damn A.D.D is right!!!
I'd forgotten about that, Jared.
I might have eventually remembered. Thanks for reminding me!
  #94
Old 09-13-2010, 07:47 PM
09Ram RT's Avatar
09Ram RT 09Ram RT is offline
Vehicle: 14' Ram 1500 Crew
Trim Level: R/T
Rep:43
09Ram RT is on a distinguished road
First off... Killer friggin install I didnt even think about using the dash location for my tweets ( I cut the door )
Anywho how did you over come the excessive high end when using the stock radio? I've been trying to tune mine for 2 months now but i just can't bring them down enough... Im about to just switch out the HU but I like the MyGig so much
2014 Dodge Ram 1500 Crew
5% Tinted Windows, Full 6000k HID kit
Lots of goodies
  #95
Old 09-13-2010, 07:58 PM
chithead's Avatar
Rep:2078
Actually, that topic was tackled this morning.
We got rid of the tweets! Seriously. Ended up crossing the pair of Dayton RS100 at 6,000Hz and then added a Vifa TG9 full range in the center channel with a cap on it to play 6,000Hz and up. This helped tremendously! It can still be a bit bright at times, but playing with the EQ has almost fixed that. Had to boost the mid about 6 bars and dropped the treble one.
  #96
Old 09-13-2010, 08:38 PM
Haze Gray's Avatar
Haze Gray Haze Gray is offline
Trim Level: SLT, Big Horn
Haze Gray is on a distinguished road
Man you are as industrious as a herd of beavers. I would have probably given up on the tweeter set ups.
  #97
Old 09-16-2010, 02:50 PM
chithead's Avatar
Rep:2078
Got some work done today, 5 1/4" mids installed in the doors, the Daytons ands TG9 are sealed up in their spots in the dash.
I also sealed up the door "pods" so as to prevent water from getting to the mids, and also a smaller enclosure can help boost the midrange:
An additional ring to help mount the mid:
And lots of weatherstripping to help seal any gaps, and to prevent door panel vibrations:
  #98
Old 09-16-2010, 02:54 PM
chithead's Avatar
Rep:2078
Dayton RS100 with 0.10mH Inductor attached, these replaced each corner dash speaker. I used velcro tape on the inductors so they can be changed out later on if I want to try cutting at different frequencies:
Vifa TG9 replaced the center channel, added a 4.7uF capacitor, again with velcro tape to allow swapping out if need be:
  #99
Old 09-16-2010, 03:03 PM
Trim Level: Custom
Rep:1648
Looks like it's starting to come together nicely.....
  #100
chithead's Avatar
Rep:2078
Only two more speakers to build enclosures for and install
Closed Thread
