Closed Thread
Old 10-16-2010, 09:11 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Things are looking up!!!
Old 10-16-2010, 09:24 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
With many many thanks to you sir they are!
  #113
Old 10-16-2010, 09:31 AM
Trim Level: Custom
Rep:1648
Gotta keep ya motivated...
  #114
Old 10-27-2010, 11:02 AM
chithead's Avatar
Rep:2078
Started mounting up the CleanSweep this morning:
CL-SSI mounted on a dash support bracket:
CL441dsp unit mounted on the back of the lower trim panel (I used washers on the bottom two screws, otherwise they would have gone right through the plastic):
Decided to color code front, rear, and sub inputs:
Test fitting wire clearances:
  #115
Old 10-28-2010, 02:26 PM
chithead's Avatar
Rep:2078
Got all the under dash connections taken care of:
Every connection soldered and heatshrinked:
All wires zip tied out of the way:
Found a great spot to tap into for the constant power, used a spade connector and plugged it right into an unused plug. Also located the keyed cigarette lighter plug for non-center console Rams and tapped into it for the ignition wire. Grounded the processors right to the dash, and voila!
  #116
Old 10-28-2010, 02:56 PM
Trim Level: Custom
Rep:1648
Looking good sir!!
  #117
Old 10-28-2010, 03:34 PM
Mista0406 Mista0406 is offline
Vehicle: 1997 Dodge Ram 1500 V8 Magnum
Mista0406 is on a distinguished road
Send a message via Yahoo to Mista0406 Send a message via Skype™ to Mista0406
Great equiptment man love the rainbow components.... But I'm also loving the JL setup also hope this gets complete man sucks you had to pull out the other setup but either way to bigger and better things keep it up man great job also keeping track of your install with pics man
  #118
Old 10-29-2010, 12:48 AM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
That is way too many wires for me... I would have gone insane after about 10 wires.
Dillon-aka, The Little Kid
  #119
Old 10-29-2010, 01:40 AM
chithead's Avatar
Rep:2078
Well the good news is it's pretty straightforward from here. Place speakers, run new speaker wire, run amp and ground, and then the remote wire comes from the DSP unit. There is a remote wire from the SSI that goes to the DSP, then from the DSP to the amp. That way if there is no radio signal through the SSI, it will not turn on the other pieces of the system. Pretty slick setup, JL really did their homework on that one.
  #120
Old 10-30-2010, 08:20 AM
chithead's Avatar
Rep:2078
Played around with speaker placement yesterday. Should be starting on some door pods and the subwoofer enclosure soon. I'm anxious to hear what these puppies are capable of!!!
Closed Thread
