ZDOG
Closed Thread
Old 08-04-2010, 04:51 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
If I could just have an 800 disc cd changer that goes through dual 24bit DAC's for my truck, I would be set. I would easily pay upwards of 5k for that
Old 08-04-2010, 04:52 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Hmmmm . . . we have a goal . . . you want to see some theory pics of that sub box I'm playing around with?
  #63
Old 08-04-2010, 04:54 PM
Trim Level: Custom
Rep:1648
You bet....
  #64
Old 08-04-2010, 05:10 PM
chithead's Avatar
Rep:2078
Obviously a very crude drawing, but gives you the idea anyways. The sub is in Chamber one, air vents into Chamber two. Both chambers then vent out at the top and bottom portion the sub is in. There will be a faceplate over the sub that creates that "coupling chamber" with the cone of the sub.
  #65
Old 08-04-2010, 05:15 PM
Trim Level: Custom
Rep:1648
I see where you are going with this, this is very similar to the H.O. box design. The sub you are using should work well in this....
BTW........Get started already!!!!
  #66
Old 08-04-2010, 05:27 PM
chithead's Avatar
Rep:2078
Here's how it would look covered...
  #67
Old 08-14-2010, 08:15 PM
chithead's Avatar
Rep:2078
Well this will come as no surprise...
But things are getting changed again.
Say hello to the bottom end of my front stage, Diamond Audio M3081.4 8" subs and Diamond Audio Hex S5.0m 5 1/4" mids...
Pretty darn beefy for just an 8" -
And the mids, these puppies bring details out that were completely lacking with the stock system, not sure if the honeycomb cones have magic speaker dust sprinkled in them, but they are amazingly detailed:
  #68
chithead's Avatar
Rep:2078
Just wait until you see where all this is going...
  #69
Old 08-24-2010, 03:01 PM
CGlines CGlines is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: SLT with Big Horn
CGlines is on a distinguished road
Any updates? I'm curious what you're up to with those 8's...
Still waiting for my stuff to get in. Can't wait to get started.
Hey, 2 quick questions... where did you end up coming through the firewall with your power wire and what did you connect your remote turn-on wire to?
  #70
Old 08-24-2010, 03:15 PM
chithead's Avatar
Rep:2078
Power wire I passed through the block off plate for the clutch master cylinder. It is right above where the main wire bundle passes through the firewall, a piece of plastic held on by two bolts (actually it's held on by two nuts but I giggle too much when I type that, so I said bolts).
No real updates yet, still waiting on the inductors to get here so I can build the crossovers for each speaker. I messed around with some quick enclosures and have the nominal airspace sorted out. Might have to learn fiberglassing to get everything where it needs to go...
Closed Thread
