Old 07-17-2010, 02:23 PM
Mojamz's Avatar
Mojamz Mojamz is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Trim Level: Laramie Crew Cab
Color: Bright White Clearcoat
Rep:25
Mojamz is on a distinguished road
Default Installed Mufflex...Lost Torque...I Think?
I just installed a new Mufflex 18" Magnaflow muffler on my 2010 Ram Hemi and took it for a test drive...I couldn't do a brake stand burn-out!!?? In fact at idle it won't rev past 3800 rpm. Wierd...with the stock muffler I could light up the rear tires with no problem. The only other mod I have installed is a drop in K&N.
Anyone else have this problem? Any ideas as to what the problem might be?
Old 07-17-2010, 02:25 PM
How big is the inlet?
I think it may just need to learn the new additional air in and out.
You could find, in your owners manual, the ECM or PCM fuse and pull it, then put it back in to reset the computer. Then go out and drive it hard so it can "relearn" your driving parameters.
Old 07-17-2010, 02:30 PM
Rep:1885
Traction control???
Rep:1885
Old 07-17-2010, 02:34 PM
Mojamz's Avatar
Rep:25
I believe it's single 3" in a double 2 1/2" out...whatever stock is.
Old 07-17-2010, 02:35 PM
Mojamz's Avatar
Rep:25
I tried with and without the traction control...I'll try pulling the fuse.
Old 07-17-2010, 02:36 PM
Mojamz's Avatar
Rep:25
MADDOG do I pull the fuse with the key on or off?
Old 07-17-2010, 02:41 PM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
Triple post in fact.
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 07-17-2010, 02:45 PM
Rep:1885
If you want to do a hard reset, pull both battery terminals off and touch them together for a couple seconds.
Old 07-17-2010, 02:53 PM
Mojamz's Avatar
Rep:25
Is this better than pulling the fuse is this case?
