Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 07-17-2010, 11:36 PM
Mac's Avatar
Mac Mac is offline
Vehicle: '99 Dodge Ram 1500 4x4
Color: solar yellow
Rep:83
Mac will become famous soon enough
Default vacuum to front axle
I have a problem with my '99 5.9L 4x4. The 4WD shifter pops out after a few seconds, both 4HI and 4LO. I understand that I should check for vacuum at the front axle but could someone please explain how to do this? I have a vacuum gauge but should it pull a certain amount of mercury? Does the truck need to be in gear and in 4WD (both axles off the ground), do I check at the axle or the transfer case? If I have vacuum, what next?
Tough part is, I have no way to test it right now. No snow and no mud (no rain), just dry pavement and gravel roads.
Thanks everyone,
-Mac
Old 07-18-2010, 12:20 AM
If the shifters popping out you need to look in the area of the transfer case . May be a linkage issue .
Old 07-18-2010, 12:37 AM
Mac's Avatar
Mac Mac is offline
Color: solar yellow
Rep:83
I should have mentioned, I adjusted the linkage. Or at least I tried. The trunnion was rusted to the shift rod pretty tight. I broke it loose but it pretty much ended up in the same spot on the shift rod after adjusting. With the linkage loose, it seemed like I could pop the shift lever back into 2HI with the slightest pressure. Is this a shift fork issue?
Old 07-18-2010, 12:45 AM
Could be in the transfer case . I think the transfer case only holds about 1 quart of tranny fluid . Have you pulled the plug out and checked the condition of it ?
Old 07-18-2010, 12:56 AM
Something else to look at is the engine/trans. mounts . Excessively worn or broken mounts can cause the lever to be pulled out of your selected range .
Mac's Avatar
Mac Mac is offline
Color: solar yellow
Rep:83
Yeah, the fluid was the first thing I checked. The case is pretty greasy, looks like the gasket used to join the two halves is leaking, but not a ton. The fluid was a little darker than normal but still red and smelled like tranny fluid. I would say the fluid was within a 1/4" of the fill hole.
BTW Tom, thanks for the quick reply.
Old 07-18-2010, 01:00 AM
Hopefully it hasn't been run low on fluid and damaged the unit .
Old 07-18-2010, 01:20 PM
Resident Technician
Rep:1915
I'm going with the linkage problem; it makes the most sense.
Old 07-18-2010, 01:52 PM
Mac's Avatar
Mac Mac is offline
Color: solar yellow
Rep:83
I'm hoping it will be that simple. Thing is, if I shift it into 4HI and crawl under the truck, I can push the shift lever (on the transfer case) just a little further into 4HI, maybe 3/16" but it feels like that's past the point of engagement and it just pops back that 3/16" anyway.
I'll try the likage adjustment again. I don't think I did a good job last time. I'll have to use a wire brush to clean the rust off the shift rod in order to get the trunnion to slide on the rod. I like the bad-mounts idea but how does one test a motor or tranny mount?
But not today, it's pouring rain.
Old 07-18-2010, 01:59 PM
Resident Technician
Rep:1915
Look for obvious signs of cracking, or sagging in the case of the motor mounts. Pry up on the trans mount to see if it's seperated.
