Place your Ad Here!
Old 07-18-2010, 09:42 AM
Mark Mark is offline
Vehicle: 2004 Ram 1500 4x4
Mark is on a distinguished road
Default overheating 4.7
temp guage almost in red: changed thermostat, no good still overheating changed water pump, no good still overheating. Pressure tested was good. Took to dealer they said might be a blown head gasket or a cracked head leaking exhaust gas into coolant. I thought a pressure test would have found either of those.
Old 07-18-2010, 10:35 AM
Resident Technician
Rep:1915
Based on my experience your radiator is partially clogged. It happens a lot in older Rams that haven't had the cooling system flushed when required. A chemical test that checks for combustion gassed in the cooling system would rule out a gasket or head problem.
Old 07-19-2010, 01:10 AM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
i agree get it rodded its like 60 bucks mine was so bad they couldnt rod it so i had to get a new radiator
