Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 07-18-2010, 04:10 PM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
Default intake plenum pan
finally got the gaskets (Fel Pro) to reassemble my engine the other day. What is recommended for sealing the bottom side of the intake? Or just install it dry?. I plan on using a little thread lock compound on the bolts, No sense having one back out and end up skating around on top of the cam!
Thanks!
Bob
Old 07-18-2010, 04:12 PM
Rep:1845
I like the spray on gasket sealer from Permatex.
Old 07-18-2010, 05:15 PM
rancherman's Avatar
Rep:171
Default pan gasket
ok thanks!
Bob
Old 12-31-2010, 12:20 AM
Deleted09's Avatar
Deleted09 Deleted09 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Base
Color: Sandstone
Rep:13
Deleted09 is on a distinguished road
These pan gaskets often leak, but it is not the gaskets fault, the problem is the bolts. On my 360, the bellypan bolts had a quarter inch long unthreaded end. The bolt bottomed out before getting the gasket tight. No wonder it leaked. I cut the unthreaded tip off the bolts, and used them. For a gasket sealant I like 3bond ( known as Yamabond to motorbike mechanics), it holds the gasket in place, and any excess is easily removed with solvent. The gasket should seal without sealant if you are getting enough torque on it, so check your bolts or use new ones.
Old 12-31-2010, 12:23 AM
Good and correct info there . Thanks for the heads up .
