Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 07-18-2010, 07:06 PM
epanzella epanzella is offline
Vehicle: 2002 Dodge Ram 2500
epanzella is on a distinguished road
Default Cummins Hot When Towing
My 2002 2500 w/5.9 Cummins always towed at 190 degrees and on a hot day if it climbed up to 210, the motor would get louder and the temp would drop right back to 190. Then the motor would quiet down again. I always assumed this was the clutch fan activating. Now the motor will climb to 240 while towing on a hot day and I don't hear the noise that I assumed was the fan kicking in. (fan is mechanical w/some sort of clutch hub). If I shut the motor off when it's real hot I can still turn the fan on it's shaft but with some resistance. Is this OK or should it be solidly locked to the shaft when hot? How do you tell if the clutch (or t-stat?) in the fan hub is good?
Old 07-18-2010, 07:19 PM
RamTech RamTech is online now
Rep:1885
If the fan assembly free-wheels without drag (the fan blades will revolve more than five turns when spun by hand), replace the fan drive. This spin test must be performed when the engine is cool.
Old 07-19-2010, 09:10 PM
Thanks, I'll check tomorrow AM.
