Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Place your Ad Here!
Old 07-18-2010, 08:02 PM
argo argo is offline
Vehicle: 1998 dodge 1500
Trim Level: larame
argo is on a distinguished road
Default whining noise on decel.
could a carrier bearing going bad cause a whining sound which could make you think it was a rearend issue
Old 07-18-2010, 08:43 PM
Resident Technician
Rep:1915
Just to clarify - you mean the midshaft bearing on the driveshaft?
Old 07-18-2010, 10:42 PM
Will the whinning noise change when on and off the throttle ? If so check the differential fluid . Is the pinion seal leaking ?
Old 07-19-2010, 04:15 AM
Trim Level: larame
yes thats what i'm calling it
Old 07-19-2010, 04:19 AM
Trim Level: larame
there is a change when on and off throttle. the fluid level was fine. i changed it out yesterday & there are no leaks
Old 07-19-2010, 04:28 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Could it....any thing is possible, but I have yet to hear a carrier bearing sound like that. If you don't have a lot of play in the rear end, you might want to check the pinion bearing. I've done 2 in the last year (Not on Dodges) for that very problem. In both cases there was very little play in the drive shaft, but it was more difficult to turn then normal (hard to turn by hand with wheels off the ground).
brad
Interested in one of my mods?
Old 07-19-2010, 01:24 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
Sounds like the pinion bearing going out. If you hear the sound (whinning) on accelarating or coasting, most likely the pinion bearing. And it will be louder as time goes on. Replace mine 18 months ago.
Old 07-19-2010, 04:52 PM
Trim Level: larame
i have about .008" backlash between the pinion & ring gear. it turns pretty freely with the drive shaft. my gear pattern on the ring gear is mostly heel loaded. i'm afraid if i try to draw up on my crush sleeve i might go too far, and have to start all over. i guess the right thing to do is pull the pinion & replace the bearing & crush sleeve. i guess you just reuse the old spacer under the bearing & hope you're in the ballpark. thanks for the info
Old 07-19-2010, 04:53 PM
Trim Level: larame
Old 07-19-2010, 05:16 PM
Resident Technician
Rep:1915
You're at the limit of your backlash setting. Spec is .005-.008"
