Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 07-18-2010, 10:26 PM
Appaloosa Appaloosa is offline
Vehicle: 2012 Ram 3500 4X4
Appaloosa is on a distinguished road
Default Clutch not disengaging
Hi Guys
I have a problem with my 96 Dakota 3.9l 4x4 manual transmission.
Last week I changed out the engine 560+ km and changed the clutch. Everything seemed to be good for about 300 km and then the clutch won't disengage.
i checked the slave cylinder as best I could, couldn't see anything the matter so proceeded to pull the tranny. I have it all apart now and can not see anything out of the ordinary. I made a block to hold the linkage on the slave cylinder and it pressures up solid when you step on the clutch.
So my question is would I have had air in the slave cylinder or is there something else I am missing?
Thanks for any help.
Dan
Old 07-19-2010, 12:33 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Tough call Dan.
My first instinct would be air in the system. With air, it would likely appear to operate properly when out in the open, but would fail went it had a load on it. As the clutch system should self bleed, is there any chance that the hose was routed differently when you put back together? If the hose is routed in a downward direction, it can't self bleed. It's just speculation at this point, as it is possible there is nothing wrong with the clutch hydraulics, and the problem may be in the clutch system itself.....like a loose pressure plate.
Just ideas.....more like.....thinking out loud.
brad
Interested in one of my mods?
Old 07-19-2010, 08:18 AM
Rep:1885
Are you sure the rod end was in the release arm correctly?
Old 07-19-2010, 10:08 PM
Thanks for the replies.
As best I could see everything was in place. The only thing that blew my mind was why did it work for 3 days and then quit. Any way I am working at putting it back together again... hoping that it was just airlocked.
I will post again when I have it done.
Thanks again
Dan
Old 07-19-2010, 11:00 PM
Rep:1885
One of the cylinders may be bypassing internally.
Old 07-23-2010, 08:38 AM
Well I finally got the time to put it all back together AND it is working properly||
Now I remember why I don't like working on trucks hahaha. Mostly when you don't get to wash all the mud out from under them.
Thanks again for the input.
Dan
Old 07-23-2010, 10:16 PM
brad12kx's Avatar
Rep:2581
That's good news.....I think. Would have been nice to know exactly what the issue was. Kind of a confidence thing. Oh well.....at least your up and rolling. Here's hoping it stays on the working side.
brad
