Old 07-19-2010, 11:07 PM
MrCantu's Avatar
MrCantu MrCantu is offline
Vehicle: 2002 Dodge Ram 1500
Rep:164
MrCantu has a spectacular aura aboutMrCantu has a spectacular aura about
Exclamation HIDs Questions...
Ok guys so I want to buy HIDs, on my 98 chevy blazer I have 10000k, I installed them, pretty strait forward... However I heard tons of things about installing them on Dodge trucks: I have a 2002 dodge ram 1500 quad cab, I wanna go with 6000k, the thing is that im confused with what to buy: cancelers or relay harness or resistors, also I have fogs, so please guys help me out.
These are just some sites I've been looking...
http://www.ddmtuning.com/Product-Cat...hting/HID-Kits
http://www.hidxenonheadlights.com/Dodge-Ram-HID-Kits/
http://www.xtremehids.com/product_in...products_id=89
http://www.buyhidkits.com/8000khidkits.html
http://www.tophidkits.com/hidrelay.html
I don't really wanna too much on HIDs but I would like them to be reliable !
Thanks in advance!
Old 07-20-2010, 12:01 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I think Maddog has a write up of some sort from when he did his HIDs.
I have HIDs from DDM in my truck, they have been great so far. They are the 6k ones.
Old 07-20-2010, 12:12 AM
MS520's Avatar
MS520 MS520 is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi
Rep:109
With the Dodge, you will encounter flickering and the "lamp out" issue. The fogs are 100% plug and play so I would get them from DDM Tuning. With the lows, if I could, I would start over and try to piece together something so that the lows work no problem.
With the DDM kit you will get the hi/lo for $60 + shipping. Then you have to find a resistor that will work. I have yet to find one that gets rid of the flickering. I don't have "lamp out" though. I just wish I could get rid of the damn flickering thing!
The other sites I can't say anything about because I have never used them.
We also have a vendor that will send you everything that we need for $100 overnight but that is only for the low beam.
If that vendor could hook me up with a resistor or something to get rid of the flickering issue then that would be great!
P.S. I LOVE my 6000K.
Mike
'04 Ram
"Yea its got a hemi!"
Old 07-20-2010, 12:14 AM
One of the kits would work, i.e., direct plug and play, a resistor harness arrangement, a capacitor oriented harness or a relay harness.
My truck required the relay harness to eliminate the flickering problem.
Old 07-20-2010, 12:26 AM
MS520's Avatar
Trim Level: Hemi
Rep:109
But how can you setup a relay harness and hi/low harness together?
Mike
'04 Ram
Old 07-20-2010, 09:03 PM
MrCantu's Avatar
Rep:164
agh it sounds kind of complicated!
Old 07-20-2010, 09:07 PM
mattg1500's Avatar
mattg1500 mattg1500 is offline
Vehicle: 2005 Dodge Ram QC
Rep:22
mattg1500 is on a distinguished road
im facin the same dilemma. I asked about this in a posting called NEW HEADLIGHTS and everyone told me go with ddm......but i dont want flickering either soooooo. maybe check out what everyone wrote to me in that post, lots of info
Old 07-21-2010, 12:11 PM
angshan's Avatar
angshan angshan is offline
Vehicle: 2004 dodge ram 1500 quadcab
Trim Level: SLE
Color: forrest green two tone
Rep:83
angshan will become famous soon enough
use this schematic to run your hi's and lows at the same time when on hi beam. this will not solve the flickering problem though.
Old 07-21-2010, 01:08 PM
The relay harness I have included a trigger wire to the high beam circuit (I have one headlight that is the low and high beam) so that trigger wire activates the high beams when I need them. It works just like the factory arrangement with halogens.
The relay harness was required to solve the flickering problem on my truck.
Old 09-23-2013, 03:20 PM
sasdelivery713 sasdelivery713 is offline
Vehicle: 2002 Dodge RAm
sasdelivery713 is on a distinguished road
Send a message via Skype™ to sasdelivery713
I ordered this kit from DDM... i also purchased the error code eliminators( Whgich i didnt need to purcase since they dont work with the Dodge ram)... the lights came on but flickered3 or 4 times then cut off. So now im in the process of finding some resistors or capacitors?... any1 have recommendations?
DDM HID Kit, 35W, 9007 High / Low, 8000K (Kit / Package)
Bulb Type: 9007 - Hi/Lo Beam (+$20.00)
Bulb Color: 8000K
Wattage: 35 Watt
2002 Dodge RAM
Ready to Haul 24/7
hids harness relay gloria
