Dodge Ram Decals
Old 07-20-2010, 08:32 PM
thewhitneys1 thewhitneys1 is offline
Vehicle: 2002 Dodge Ram
Trim Level: 1500 Sport QC 4x4
thewhitneys1 is on a distinguished road
Default Whining noise when accelerating
Hello all! I have read many threads on here but this is the first time posting.
I recently traveled over 1k miles pulling a 4k lb. travel trailer through the Appalachian mountains from Maryland to Ohio. About 200 miles into the trip I noticed my antifreeze spewing everywhere (due to a cap not closed properly). Approximately another 200 miles into the trip, while ascending a 2400' mountain, I lost all power while going about 20 mph @ 4000 rpms (tranny overheated). Once this happened, my ABS and Emerg. Brake light came on, and the speedometer and odometer stopped working.
I made the trip to and from after refilling the coolant and the truck seemed to run okay. Luckily my GPS has a speedometer on it.
I just got the truck out of the shop, apparently my rear speed sensor on the diff broke off into the pumpkin which caused metal to disperse everywhere. I replaced the rear speed sensor and did a full tranny flush. Now, when I step on the gas (either accelerating or just to keep moving) I hear a whining sound. Talking to my mechanic, he thinks I might need to get the rear diff rebuilt.
Anyone experience anything similar? How much does a rear diff cost to be rebuilt?
Open for assistance!
Thanks,
Alex
Old 07-20-2010, 11:30 PM
Troybigred79 Troybigred79 is offline
Vehicle: 2001 Ram 2500
Trim Level: Quad cab
Troybigred79 is on a distinguished road
Hey Alex, it's odd that the speed sensor would have just broken off and fell into the differential assembly without it being hit or something. but if indeed that's the case and metal debris did contaminate the axel lube and bearings, the problem sounds like the pinion bearing has gone bad if it only happens under acceleration. i'm going to say a rear diff rebuild ( thats bearings, seals,lube, sealant and labor) would be around 300-500, if for some reason you would need new pinion gear and ring gear set the cost would be much higher. Hope this helps you out any.
Old 07-21-2010, 09:02 PM
Thanks. They took off the pumpkin cover and cleaned out some metal debris and all. I'll give it a few and see if it goes away - then check again.
Old 07-23-2010, 10:32 AM
Resident Technician
Rep:1915
Good luck but I'm with Troy on this one. I'm betting something has came loose and smacked the speed sensor. Judging by your post they haven't pulled the diff cover as of yet?
Old 07-23-2010, 06:37 PM
They did pull the diff cover off and found metal particals as a result of the speed sensor falling into the diff. They cleaned it out and replaced the fluid. I just am concerned with the whining. On other posts I have read that flushing the tranny could assist and I had that done. The sound definitely is coming from the rear of the truck. The mechanic said to give it a while and if it continues I might need to look into having the rear diff rebuilt. My concern is I pull a 3500-4000lb camper here and there and don't want to cause any issues - especially when pulling it.
Old 07-23-2010, 07:00 PM
Resident Technician
Rep:1915
If your rear diff is whining, and changing the fluid didn't make a difference then the damage is already done. It will only get worse.
Old 08-25-2010, 08:33 PM
tuckertrucker's Avatar
tuckertrucker tuckertrucker is offline
Rep:34
tuckertrucker is on a distinguished road
Default Rear End Whine
I have the same prob I replaced the lube. Also checked for metal particals nothing found to speak of. I still have the sound mostly when in coast mood.
I can feel the vib in the steering wheel and the pedals is this possible. I tow a boat also. Any ans would be helpfull.
Thanks
tuckertrucker
1995 1500 4x4 360 3in lift 33 tires Magnaflow Gibson shorties Spectre CAI modded keg 52mm tb.
