Old 07-20-2010, 11:21 PM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
Default Drive vs. 5 on the rocker switch?
Durring some experiments pursuant to my previous post I've noticed something odd. When I'm on the highway (75mph) I run at about 1900rpm when I'm in drive. However if I click the rocker switch down so the dash displays 5 I jump suddenly to 2200rpm. There is no change in speed or engine sound when this happens however and if I switch back up to drive the rpms drop again. I assumed that drive at 75mph is in 5th. Is there a 6th gear I don't know about or an alternate 5th used only in drive?
What's up with that?
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 07-22-2010, 03:07 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
its probably locking and unlocking the torque converter. Not an actual gear change.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 07-22-2010, 03:16 PM
Resident Technician
Rep:1909
Technically the 545RFE is a 6 speed transmission but only 5 gears are used through normal upshifting. The extra gear somes into play when you lay into the gas at highway speed; the transmission shifts into an alternate second gear (a true passing gear) and the upshifts back through 3, 4 and 5. I agree with Strang3majik though, you're just unlocking the converter.
Old 07-23-2010, 02:02 AM
GPSHSLAX's Avatar
Trim Level: ST 2X4
Rep:236
Ok .. so I just did a bit of reading. If I understand correctly what you both are saying is that in drive the torque convertor locks at high speed to improve efficiancy. However at 5 on the rocker switch I am unlocking the torque convertor and essentially wasteing energy at the engine now has to run at higher RMP to keep the trany spinning at the same speed?
If this is the case I have one further question. Why would the system be set up this way. What could the advantage possibly be to unlocking the torque converstor at this speed?
Old 05-24-2011, 12:03 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
I know this is an old post but thought I would correct the info for future searches.
When in ERS Mode the Double Overdrive (Top Gear) is disabled and the the gears are renumbered.
Normal Mode:
1 = 3.00
2 = 1.67
2 Prime = 1.50
3 = 1.00
4 = 0.75
5 = 0.67
ERS Mode:
1 = 3.00
2 = 1.67
3 = 1.50
4 = 1.00
5 = 0.75
Gene
Old 05-24-2011, 07:54 AM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
makes it easier while taking hills and such by turning mds off, the truck will do it on it's own, but if you keep it in 5 you don't have to worry about it. just like hitting the tow/haul button, it automatically puts it in 5.
Edit* just noticed you have the 4.7...I know nothing about the little v-8s anymore.
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
