Old 07-20-2010, 11:48 PM
nitro1965 nitro1965 is offline
Vehicle: 2013 Ram Express 1500 Quad Cab
Trim Level: exspress
Color: cherry pearl red
Rep:27
nitro1965 is on a distinguished road
Default need help with p1128 dtc code
hello, i have a 2006 dodge ram 1500 quad cab 4 x4 with a 5.7 hemi. it is an automatic with 45,000 miles.the problem i have been having for the past 3 weeks is that the engine lite came on . i read the code and it was p300 which i was told is a misfire code, and the other code p1128 is a manufacturer dtc code. i put new oem spark plugs in .a friend of mine owns a auto garage and has a snap on mathis code reader which reades everything on your vehicle. we could not pin point the issue.has anyone come across a p1128 code . my truck does at times seems to run sluggish but not bad .it seems to be running fine. evertime i tried to reset the code it just comes back. if i could have some input on what could be the issue it would be helpfull
Old 07-22-2010, 11:14 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
how did the old plugs look? colorwise? gaps ok? maybe check an clean throttle body as well..
Old 07-22-2010, 11:20 AM
Rep:1845
P1128 indicates the left bank of your engine isn't achieving closed loop mode. Possible causes are:
RESTRICTED FUEL SUPPLY LINE, FUEL PUMP INLET STRAINER PLUGGED, FUEL PUMP MODULE, O2 SIGNAL CIRCUIT, O2 RETURN CIRCUIT, 1/1 O2 SENSOR, MAP SENSOR, ECT SENSOR, ENGINE MECHANICAL PROBLEM, FUEL FILTER/PRESSURE REGULATOR, POWERTRAIN CONTROL MODULE (PCM)
Old 07-23-2010, 02:06 AM
Rep:27
the plugs looked normal other than the gap being more than .45. when i put in new oem plugs i made sure they all had a .45 gap. i did clean the throttle body it had some black carbon all around it .i also took the throttle body plate off to clean deeper in side.the truck still throws out the p1128 code ,and today it also threw out a p0132 code which is an o2 sensor.the truck is starting to run rough at idle but while driving it seems normal.
Old 07-23-2010, 04:11 AM
chefred112's Avatar
Rep:656
how about the pcv valve? cheap enough to just replace
Old 07-23-2010, 07:49 AM
Troybigred79 Troybigred79 is offline
Vehicle: 2001 Ram 2500
Trim Level: Quad cab
Troybigred79 is on a distinguished road
I have had quite a few issues with the o2 sensors on the Hemi engines. Try and look at the fuel adaptives for bank 1 and see if they are way negative. I have had alot of these come to the dealer now with p0300 codes and after diagnosing, I have been replacing 1/1 and 1/2 o2 sensors and the issue correct itself. I think a 2006 should still cover the sensors under warranty due to it being an emissions related problem. hope this helps
Old 07-23-2010, 08:34 AM
Rep:1845
Really? I haven't seen that at our dealership but I'll keep it in mind. Are you seeing it on the non-MDS engines as well?
Old 09-24-2013, 07:01 PM
ddemartino ddemartino is offline
Vehicle: 2006 ram 1500 mega cab
ddemartino is on a distinguished road
im having the same issue. seems to do it only when its cold. did you find the problem?
