Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Place your Ad Here!
Old 07-21-2010, 08:41 AM
lucas318's Avatar
lucas318 lucas318 is offline
Vehicle: 1996 Dodge Ram
Rep:29
lucas318 is on a distinguished road
Default need bearing clearance range
im building a 318/5.2l magnum motor, i got a crank that was turned .010 under, so i ordered my bearings to be plus .010. now im at the stage of using plastigauge, im getting .0025, now all the damn Haynes book list in the maximum oil clearance for for the mains is .0047, and the rod .0035, so what are the minimum?
thanks
Old 07-21-2010, 09:20 AM
lucas318's Avatar
Rep:29
I called the place i bought the bearing, Hughes Engines. the tech guy Dave said the .0025 is prefect, thou hes not a fan of plastigauge.
Old 07-21-2010, 10:25 AM
Resident Technician
Rep:1915
What method does he use to check bearing clearances???
Old 07-21-2010, 10:29 AM
Resident Technician
Rep:1915
Bearing Clearance (#1 Journal) - 0.0005 - 0.0015 in.
Bearing Clearance (#2-5 Journals) - 0.0005 - 0.002 in.
This info is taken straight from the Chrysler service infor for the '96 5.2L.
Old 07-21-2010, 12:38 PM
lucas318's Avatar
Rep:29
hes like to use a mic, which arent cheap, so i used what i could afford.
so then i guess the .0025 is ok for #2-#5, not #1
i used plasticage, the green which is .001 to .003, then i got confused used the red, which .002 to .006, so the green was right to use. so tonight ill do it all over again to be 100%.
did you see the clearance for the rod bearing? or go that link for the service info?
Old 07-21-2010, 12:41 PM
Resident Technician
Rep:1915
Rod Bearing Clearance - 0.0005 - 0.0022 in.
