Old 07-22-2010, 07:32 PM
1970swbc10's Avatar
1970swbc10 1970swbc10 is offline
Vehicle: 1999 Dodge Ram 1500 4X4
1970swbc10 is on a distinguished road
Default Dextron III in my 46RE??????
I just picked up my truck at the tranny shop after the installation of a Jasper Reman. I noticed the Dextron III bottles beside the lift an asked what fluid they used. The installer said Dextron III.
I then called the Jasper tech line and was told to use ATF+4. He said if they used Dextron that it was not compatable with the torque converter and it would start chattering.
I asked the installer for the instruction sheet that came from Jasper. Sure enough, it specified ATF+4, period.
It's a good thing I have the 3 year warranty. It's already chattering after only about 50 miles.
I think I'll look for a new tranny shop.
So, anyone installing a new trans, specify ATF+4.
JEFF
Old 07-22-2010, 07:39 PM
ATF+4 is awesome tranny fluid . When I first got my Snap on Scanner , I hooked it up to a Buick LeSabre for a torque convertor clutch shudder problem . The scanner recommended installing Chrysler ATF fluid . So whats that tell ya about the fluid .
Old 07-22-2010, 08:48 PM
1970swbc10's Avatar
I think I'll go to Express Lube tomorrow and have ALL the Dextron removed and replaced with ATF+4.
Anyone have any experience with the Express Lube trans fluid replacement procedure?
JEFF
Old 07-22-2010, 08:59 PM
I would take it back to the installer and have him do it at his expense .
Old 07-22-2010, 09:06 PM
1970swbc10's Avatar
I did. He drained the pan through the fill tube and removed about 4 quarts. Then he put 6 quarts back in. I took it home and drained the excess 2 quarts.
Would you take your truck back to that shop???
JEFF
Old 07-22-2010, 09:28 PM
Did Jasper recommend him as a installer of their product ? If so contact Jasper and let them know what he did .
Old 07-22-2010, 09:50 PM
Rep:1877
You need a complete system flush with ATF+4. If the chattering continues, that shop owes you a new transmission.
Old 07-22-2010, 09:54 PM
1970swbc10's Avatar
Yes, he is a Jasper preferred installer, but my shadow will never darken his door again.
I'll pay for the trans flush and refill with ATF+4. Was just curious if anyone had any experience with the Express Lube type evacuation. I haven't heard anything, pro or con.
JEFF
Old 07-22-2010, 10:04 PM
I would still contact Jasper and rat him out . I haven't heard of Express Lube but you can drop the pan again , flush the lines and cooler . Years ago if the convertor didn't have a drain plug , mechanics would drill and tap the convertor and install a 1/8 " pipe plug . The convertor holds quite a bit of fluid . I'm not sure your gonna find anyone nowadays who will do that .
Old 07-22-2010, 10:50 PM
Rep:1877
Just have a complete system flush done. It will get all the fluid including what's in the converter.
