318 to 360 engine swap - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-15-2010, 08:53 PM
jroach1018 jroach1018 is offline
jroach1018 is on a distinguished road
Default 318 to 360 engine swap
hi im looking to swap my current 318 to a crate 360.... what parts will i need inorder for a smooth swap
thanks in advance
Old 05-20-2010, 09:01 PM
TwoDogs's Avatar
TwoDogs TwoDogs is offline
Vehicle: 2011 Ram2500 , 97 Ram, 69 D100
Trim Level: laramie
TwoDogs is on a distinguished road
have you looked into a 318 stroker??
08' hemi, 97' 5.2, 69' D100
Old 05-20-2010, 09:14 PM
no, my engine has 150k on it and is starting to run rough so i am thinking of doing the engine swap myself but it would be helpful to know everything id need for the 360 swap... i have a haynes repair manual to assist me
Old 05-20-2010, 10:05 PM
Stoner421's Avatar
Stoner421 Stoner421 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Laramie
Color: Red, Silver/Gray, and Black primer
Stoner421 is on a distinguished road
thanks in advance
Hey Jroach,
From what I have been told, you would need to buy a wiring harness for the 360, along with the computers to go with it.
Note: If I am wrong in this, could someone please inform me? If I am wrong I was told wrong!
Stoner
Old 05-20-2010, 10:06 PM
Rep:1915
SHouldn't need much of anything outside of tools and maybe a few new gaskets. You will need to have the PCM flashed with 5.9 software though.
Old 05-20-2010, 10:57 PM
i think i will need a new torque converter... will be replaceing the engine mounts but every thing else should be an exact fit?
Old 05-26-2010, 07:39 PM
BIGYELLOW BIGYELLOW is offline
Vehicle: 1994 Dodge 1500
BIGYELLOW is on a distinguished road
Exactly what year is your truck. I just did the swap from a 318 to 360. motor mounts are the same the heads are the same, only thing different is 318 is internally balanced and 360 externally balanced, you need to change balancer and oil pan. If you have a flexplate with the weights on it for a 360 then u can use the converter without weights on it. if u reuse your flexpate from your 318 you have to use a converter with the weights on it. Wiring harness is the same and if it is older truck u can use your 318 ecu it will just run lean.
Old 05-28-2010, 02:34 PM
thank you for the reply... its a 96 single cab 8ft bed, i think i will get the weighted converter and i already have a 360 ecu
thank you for your help
Old 06-09-2010, 03:31 PM
fixerlr fixerlr is offline
Vehicle: 1998 Dodge ram 1500 ext cab
Color: White/Blue two tone not factory
fixerlr is on a distinguished road
Send a message via Yahoo to fixerlr
hey stroker can tou get alittle more in detail about this stroker I have a 98 ram 1500 with 200k on it and I am thinking about doing something with the engine and ofcourse I want more power is there a kit or do you have to buy crank and rods seprate
Old 07-03-2010, 05:59 PM
TwoDogs's Avatar
Trim Level: laramie
you can either buy a kit and do all machine work or you can get a "short block" (Block that has been machined and crank, pistons, and all installed) I think you an even get a complete engine stroked to 392 ci. Just depends on your budget I guess. Check Ebay.
